Data failing to get logged in SD card
Hi, I have an SD card, and the GPS (NEO 6M GPS module)data gets stored in it when GPS is used as a standalone sensor. But when I try to insert DHT 11 sensor ( for temperature and humidity) it shows "error opening GPS_data.txt" and nothing gets stored in the SD card. Only a blank txt file named GPS_data.txt gets created. How to solve this issue? I am attaching the entire code for reference.
#include "SD.h"
#include <SPI.h>
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <dht.h>        // Include library
#define outPin 7        // Defines pin number to which the sensor is connected
dht DHT;                // Creates a DHT object
File myFile;
int RXPin = 3;
int TXPin = 2;
TinyGPSPlus gps;
SoftwareSerial SerialGPS(RXPin, TXPin);
String Latitude, Longitude, Altitude, day, month, year, hour, minute, second, Date, Time,Temperaturee,Temperatureee ,Humidity,my_Str,Data;
        float t = DHT.temperature;        // Read temperature
        float t1;                            // read temperature in Fahrenheit
	float h1 = DHT.humidity;           // Read humidity
    while (!Serial) {
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  Serial.println("Creating GPS_data.txt...");
  myFile = SD.open("GPS_data.txt", FILE_WRITE);
  if (myFile) {
    myFile.println( "Latitude, Longitude, Altitude, Date , Time (UTC), Temperature in C, Temperature in F , Humidity in % \r\n"); //Write the first row of the excel file
    myFile.close();
    Serial.println("error opening GPS_data.txt");
 SerialGPS.begin(9600);
  while (SerialGPS.available() > 0)
    if (gps.encode(SerialGPS.read()))
      obtain_data();
  if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println("GPS NOT DETECTED!");
    while(true);
void obtain_data()
 my_Str=String(",");
  if (gps.location.isValid())
    Latitude = gps.location.lat();
    Longitude = gps.location.lng();
    Altitude = gps.altitude.meters();
    Serial.println("Location is not available");
  if (gps.date.isValid())
    month = gps.date.month();
    day = gps.date.day();
    year = gps.date.year();
    Date = day + "-" + month + "-" + year;
     Serial.println(Date);
    Serial.print("Date Not Available");
  Serial.print("Time (UTC): ");
  if (gps.time.isValid())
    if (gps.time.hour() < 10) ;
    hour = gps.time.hour();
    if (gps.time.minute() < 10);
    minute = gps.time.minute();
    if (gps.time.second() < 10) ;
    second = gps.time.second();
    Time = hour + ":" + minute + ":" + second;
  Serial.println(Time);
    Serial.print("Time Not Available");
      Serial.print("Tttemperature = ");
      Temperaturee  = String(t);
      Serial.print(Temperaturee);
	Serial.print("°C | ");
	t1=((t*9.0)/5.0+32.0);        // Convert celsius to fahrenheit
  Temperatureee = String(t1);
  Serial.print(Temperatureee);
	Serial.println("°F ");
	Serial.print("humidity = ");
	Humidity= String(h1);
  Serial.print(Humidity);
	Serial.println("% ");
	Serial.print("\n");
  Data = Latitude + my_Str + Longitude + my_Str + Altitude + my_Str + Date + my_Str + Time  + my_Str +Temperaturee + my_Str +Temperatureee + my_Str + Humidity;
//Data = Latitude + "," + Longitude + "," + Altitude + "," + Date + "," + Time;
  Serial.print("Save data: ");
  Serial.println(Data);
  if (myFile) {
    Serial.print("GPS logging to GPS_data.txt...");
    myFile.println(Data);
    myFile.close();
    Serial.println("done.");
 delay(3000);
#include "SD.h"
#include <SPI.h>
File myFile;
int RXPin = 3;
int TXPin = 2;
TinyGPSPlus gps;
String Latitude, Longitude, Altitude, day, month, year, hour, minute, second, Date, Time, Temperaturee, Temperatureee , Humidity, my_Str, Data;
  while (!Serial);
  if (!SD.begin(4)) {
    while (1);
  if (myFile) {
    myFile.close();
      obtain_data();
    while (true);
void obtain_data() {
  my_Str = String(",");
  if (gps.location.isValid())  {
  else Serial.println("Location is not available");
  if (gps.date.isValid())  {
    Date = my_Str + day + "-" + month + "-" + year;
  else Serial.print("Date Not Available");
  if (gps.time.isValid())  {
  else      Serial.print("Time Not Available");
  t1 = ((t * 9.0) / 5.0 + 32.0); // Convert celsius to fahrenheit
  Humidity = String(h1);
  Serial.print("\n");
  Data = Latitude + my_Str + Longitude + my_Str + Altitude + my_Str + Date + my_Str + Time  + my_Str + Temperaturee + my_Str + Temperatureee + my_Str + Humidity;
  if (myFile) {
    myFile.close();
  delay(3000);
Verify your DHT is on pin 7 (and SD CS is on pin 4).
[edit]
I wonder if the SD is having power issues... either too little or too much... with the DHT in the circuit. Have you tried commenting-out all the DHT code (but DHT still getting power, but not connected to the Arduino pin 7)?
[/edit]
DHT is on Pin 7 and SD CS is at pin 4. But the problem arises when GPS has been connected then everything goes for a toss regarding SD card. Otherwise without GPS , I have collected and recorded data to SD card from three sensors ( DHT11, Soil moisture sensor, and another waterproof temperature sensor) simultaneously. Everything has been done withut any hassle. But this GPS becomes headache. In the serial monitor everything is fine ( GPS along with DHT sensor gives output ). I will implement your suggestion in the morning in my lab
I will implement your code in my lab in morning.
How is the GPS getting power? They draw up to 2A... so not (getting power from) the Arduino.
[edit]
You will see a comma issue in this line...
Data =/*(no comma)*/ Data /*(no comma)*/ + Latitude + my_Str + Longitude + my_Str + Altitude + my_Str + Date + my_Str + Time  + my_Str + Temperaturee + my_Str + Temperatureee + my_Str + Humidity /*(no comma)/*;
so, you say now that DHT was first and GPS messed everything up.
now i understand, in sketch every variable about DHT is casted properly,
String x = String (float)
lcd.print(x)
but no one single variable is casted by obtaining from GPS,
String Latitude = gps.location.lat();
i think any of this strings is empty and
stores nothing
if i am right then sd contains many empty lines
i changed my_Str variable from space to comma, now empty lines would be ",,,,,,,," and visible
This is how your data will look...
More likely no than yes
The format is a direct copy/paste, so yes, as I described. The commas will need to be worked. No comma at the record start, but past the start, the next record will need a comma... or the CSV will be a mess.
it was in my sketch
Data =Data+
i misplaced data and date
whatever. for me is only important what is in the SD Card file. what was and what is now.
if there ",,,,,,," then casting is mandatory.
Your data will be better (to use) if you take care of the commas... and ease up on your cynicism.
Context. Use it better results.
I formatted the SD card and modified the code a little bit but it now says "initialization failed!". I don't get what happened now. I am attaching the modified code for reference.
#include "SD.h"
#include <SPI.h>
File myFile;
int RXPin = 3;
int TXPin = 2;
TinyGPSPlus gps;
float LAT, LONG, ALT;
  while (!Serial);
  if (!SD.begin(4)) {
    while (1);
  if (myFile) {
    myFile.close();
      obtain_data();
    while (true);
    LAT = gps.location.lat();
    Latitude = String(LAT);
    LONG = gps.location.lng();
    Longitude = String(LONG);
    ALT = gps.altitude.meters();
    Altitude = String(ALT);
  Serial.print("\n");
  if (myFile) {
    myFile.close();
  delay(3000);
reattach to pc, if it seems alright, use secure disconnect function of operating system.
Can you guide me that" how to use secure disconnect function of operating system"? SD card is alright and it is storing the data ( like music files and other stuffs). But not working in my progam.
This process I always follow while ejecting external storage devices. But here the problem is with the SD card things are all right ( in context of my program writing) before formatting. But after formatting SD card initialization failed. But SD card can be used for other purposes like storing music videos , movies etc.
i: ask you what text is in the generated file
you: formating sd card
why? was it secret information? so secretly that you must format complete SD card?
i see no changes in sketch. what has you modified?
In the generated file another .txt has been stored as one of my colleagues used that SD card so before using that I formatted the SD card as I am seeing in some internet articles that it is better to format SD card before a new use. So I did accordingly and after that, the problem arises.
As far as code modification is concerned, I tried to modify this ( incontext to my previous code)
now i see. thank you. ok. when you formatted SD card which system do you chose NTFS/FAT32/exFAT ?
exFAT because FAT32 is not showing as an option. NTFS and exFAT is showing and I choose exFAT.
