Is there any way you can receive data from a sensor and the arduino would easily be able to put that data into a table?
It depends upon what you mean by "... put that data into a table" and "... easily ...".
Please explain further.
My table is highly polished, and has one leg that is a tiny bit shorter than the other two. Every time I put data on it, it slides right off onto the floor.
Most tables that I have seen have four legs or more. A three legged table is unusual but rests on any floor without rocking. Objects on the table may slide off, however.
I mean can the board edit a table (meaning like a type of graph) in a program that you know of?
A table an excel spreadsheet?
A table in an access database?
A table in a SQL database?
A table in a text file?
A data file on an SD card attached to the arduino?
You really need to help us out with a better definition of what you are trying to do.
YoungsterSP:
The Arduino can store data in a 2D array (that being one definition of "table"). If you look at your Arduino, you'll be hard-pressed to find a way, without external hardware, to display "a graph".
I want an array with data values in it that the arduino can edit with data coming in from Sensors. I just don’t know what software to use to display the table. Can you edit an excel sheet automatically with data from an arduino? I want a simple table that doesn’t have long strings of text like the serial monitor.
I just don't know what software to use to display the table.
First, you have to get the data out of the Arduino...
Google PLX-DAQ.
Use 'PLX-DAQ'
https://forum.arduino.cc/index.php?topic=437398.0
I would like to make a real time table that organizes a lot of data for me. I am using 3 load cells and they are telling me weights. Those values change over time and I want it to tell me in the table. I do not want a long string of microscopic changes, because I would rather have it in a nice and concise real time table. Excel just lets you put your serial monitor on to it. It does not let you replace values, but instead it creates a string.
Yeah, you got it! Since I am new to all of this would you mind linking some information on how to do this, because as a new person to Arduino I don't quite know what to look for. Thank you so much!
A good link is LMGTFY - Let Me Google That For You
A good link is Arduino Processing
