Hey.
How to get this data from a BME680 sensor, along with a wemos d1 mini to a Blynk apps ?? I cant see data on my serial monitor in the Arduino IDE.
How to get it over with Blynk apps.
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME680 bme; // I2C
while (!Serial);
Serial.println(F("BME680 test"));
if (!bme.begin(0x77))
Serial.println("Could not find a valid BME680 sensor, check wiring!");
while (1);
// Set up oversampling and filter initialization
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150); // 320*C for 150 ms
if (! bme.performReading())
Serial.println("Failed to perform reading :(");
return;
Serial.print("Temperature = ");
Serial.print(bme.temperature);
Serial.println(" *C");
Serial.print("Pressure = ");
Serial.print(bme.pressure / 100.0);
Serial.println(" hPa");
Serial.print("Humidity = ");
Serial.print(bme.humidity);
Serial.println(" %");
Serial.print("Gas = ");
Serial.print(bme.gas_resistance / 1000.0);
Serial.println(" KOhms");
Serial.print("Approx. Altitude = ");
Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
Serial.println(" m");
delay(2000);
Code is from this website BME680 environment sensor and ESP8266 example - esp8266 learning
#include <Wire.h>
#include <SPI.h>
#include <Blynk.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
//Setup connection of the sensor
char auth[] = "xxxxx";
char ssid[] = "xxxx";
char pass[] = "xxxx";
BlynkTimer timer;
while (!Serial);
if (!bme.begin(0x77)) {
while (1);
Blynk.begin(auth, ssid, pass);
timer.setInterval(5000L, ReadSensors); // read sensor every 5s
void ReadSensors(){
//Read values from the sensor:
if (! bme.performReading()) {
return;
delay(10);
float a = bme.readTemperature();
float b = (bme.readPressure() / 100.0F);
float c = bme.readHumidity();
float d = (bme.gas_resistance / 1000.0);
float e = bme.readAltitude(SEALEVELPRESSURE_HPA);
Blynk.virtualWrite(V0, a);
Blynk.virtualWrite(V1, b);
Blynk.virtualWrite(V2, c);
Blynk.virtualWrite(V3, d);
Blynk.virtualWrite(V4, e);
Blynk.run();
timer.run();
