Data From Pachube
I'm getting values from Pachube using a WiShield and using an RGB LED to reflect the values. Upon starting up I get the values from Pachube , but can never seem to get the values a second time.
I have a loop where it calls Pachube every 20 seconds for 4 tries if this doesn't work then it switches to waiting another minute, then goes back to the 20 seconds for 4 tries. Basically I want it to call Pachube until it gets a value, then wait a long time like half an hour before calling again.
I think I have a memory issue because sometimes the Arduino goes wonky and resets itself and I never get any more data. How do I clean out my memory or reset it to 0? How do I get values from Pachube a second time?
    * Thanks to the following people who made this project possible
   Miguel Sanchez for the Arduino mood light code
   Greg Eigsti & Voyager from the Asynclabs boards.
   This project uses 2 Arduino boards and 2 Wishields
    #include <WiShield.h>
    #include <WiServer.h>
    #include <MsTimer2.h>
    #define WIRELESS_MODE_INFRA   1
    #define WIRELESS_MODE_ADHOC   2
 #include <stdio.h>
char field [ 64 ];
 // Wireless configuration parameters ----------------------------------------
unsigned char local_ip[] = {192,168,1,2};      // IP address of WiShield
unsigned char gateway_ip[] = {192,168,1,1};      // router or gateway IP address
byte subnet_mask[] = {255,255,255,0};   // your subnet mask for the local network
const prog_char ssid[] PROGMEM    = {"Your Network Name"};      // max 32 bytes
unsigned char security_type = 0;   // 0 - open; 1 - WEP; 2 - WPA; 3 - WPA2
// WPA/WPA2 passphrase
const prog_char security_passphrase[] PROGMEM = {"12345668"};      // max 64 characters
prog_uchar wep_keys[] PROGMEM = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d,      // Key 0
                          0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,      // Key 1
                          0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,      // Key 2
                          0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00      // Key 3
    // WEP 128-bit keys
    // sample HEX keys
    // setup the wireless mode
    // infrastructure - connect to AP
    // adhoc - connect to another WiFi device
    unsigned char wireless_mode = WIRELESS_MODE_INFRA;
    unsigned char ssid_len;
    unsigned char security_passphrase_len;
    //global state data
    boolean intTimer;
    boolean gotData;
    int temp1;
    int temp2;
    int sun;
  int x=0;
  int statey =0;
  int resetShield=0;
    unsigned int timercount = 0;
   unsigned int successes = 0;
  // unsigned int failures = 0;
int val;  // use to read a byte from the serial
int state=0;
    int i=0;
    boolean inValidPacket;
    char recvData[400]=" ";
    // IP Address for Pachube.com
    uint8 ip[] = {209,40,205,190};
   char hostName[] = "www.pachube.com\nX-PachubeApiKey: "Your key here"\nConnection: close";
   char url[] = "/api/29.57.csv?_method=put";
GETrequest getPachube(ip, 80, "www.pachube.com", "/api/2957.csv HTTP/1.1\nHost: pachube.com\nX-PachubeApiKey: c8a045ad5501e612c71319394c5aa77241172ed0ee66f071558d9660d8b54aa0\nConnection: Close\n");
int r=0;
int g=0;
int b=0;
    //MsTimer2 one minute timer ISR
    void timerISR() {
       intTimer = true;
   void printGetData(char* data, int len) {
   //if we are not in the middle of a packet AND we find the OK token
   if(false == inValidPacket && NULL != strstr(data, "HTTP/1.1 200 OK")) {
      //mark that we are in a valid packet
      inValidPacket = true;
      //temporary for debugging purposes
      Serial.println("Data reception started");
   else {
     // Serial.println("How did we get here?");
   //if we were in a valid packet AND we get the ending 0 == len call
   if(true == inValidPacket && 0 == len) {
      //mark that we are no longer in a valid packet
      inValidPacket = false;
      //grab out the values with something like sscanf()
      // Need to point sscanf to the right place
//char *data; //data from the WiShield - set to something like the "re-hydrated" string above
//char *begin;
//char *end;
const char *ptr = recvData;
   int n;
   while ( sscanf(ptr, "%64[^\n]%n", field, &n) == 1 )
      printf("field = \"%s\"\n", field);
      Serial.print ("Field = ");
      Serial.println(field);
      if(strlen(field) <= 15 && (strlen(field) > 4))
           scan2();   //parse out last bit of data
      delay(10);
      ptr += n; /* advance the pointer by the number of characters read */
      if ( *ptr != '\n' )
         break; /* didn't find an expected delimiter, done? */
    while ( *ptr == '\n' )
        ++ptr; /* skip the delimiter */
      Serial.println("Data reception ended");
      Serial.println("Data string  = ");
      Serial.println(recvData);
      Serial.println(" ");
      Serial.println("Values from sscanf");
      Serial.print("Temp 1 ");
      Serial.println(temp1);
      Serial.print("Temp 2 =  ");
      Serial.println(temp2);
      Serial.print("Sun =  ");
      Serial.println(sun);
      //reset the received data buffer to all 0s - clean up...memset 400
      memset(recvData, 0, 400 * sizeof(char));
   else {
      //just being anal... probably not needed
      //stash away the last bit of data received
      memcpy(recvData, data, len);
      Serial.println("Received data:");
     // Serial.println(data);
     Serial.begin(57600);
    Serial.println("Connecting...");
   // WiFi.init();
     rgb(5,255,25);// write values
   // gotData=false;
      WiServer.enableVerboseMode(false);
     // Initialize WiServer (we'll pass NULL for the page serving function since we don't need to serve web pages)
      WiServer.init(NULL);
     //init global data; add to, not replace, what is in your setup() function
      // Have the processData function called when data is returned by the server
      getPachube.setReturnFunc(printGetData);
      //set up global state data
      intTimer = false;
      //setup the timerISR to be called every xxxxx ms
      MsTimer2::set(20000, timerISR); // 60000ms/1min period
      MsTimer2::start();
Serial.println("Connect Timer 20 sec");
if(statey==1)
   colorchange();
       //handle the timer overflow
       if(true == intTimer) {
           //Time has has passed
          intTimer = false;
          Serial.println("== Timer fired ==");
          MsTimer2::start();
          Serial.print("timer 20 sec");
          Serial.print("\nTotal calls= ");
          Serial.println(++timercount);
          getPachube.submit();
          if (getPachube.isActive()) {
          Serial.print("\nSuccess calls= ");
          Serial.println(++successes);
            if(successes >=4)
              Serial.println("Timer 1 min");
              successes=0;
               MsTimer2::set(60000, timerISR); // 60000ms/1min period
               MsTimer2::start();
               Serial.println("Reset Connection");
               WiFi.init();
               gotData=false;
            if(gotData==true)
              successes=0;
               MsTimer2::start();
               WiFi.init();
               gotData=false;
      // Run WiServer
      WiServer.server_task();
      delay(10);
    void scan2()
  Serial.println("Parsing..");
  sscanf(field, "%d,%d,%d", &temp1, &temp2, &sun);
  Serial.print("Variable 1-3 = ");
 // Serial.print("Variable 2 = ");
//  Serial.print("Variable 3 = ");
  gotData=true;
  statey=1;
   Serial.println("Time 1 min ");
  MsTimer2::start();
// memset(field, 0, 100 * sizeof(char));
if (temp1<=32)
  b=temp1;
  r=(temp2*2+25);
  g=sun;
 else if (temp1<=60)
  b=temp1*2;
  r=temp2*2;
  g=sun+10;
  b=temp1*2+25;
  r=temp2-25;
  g=sun+75;
  successes=0;
void colorchange()
  int color,i,value,time=25;  // how long does it take each step
  color=random(1,4);    // which color to dim now
  value=random(temp1,256);  // new value of that color
 /* Serial.print("Value = ");
  Serial.println(value);
    Serial.print ("R = ");
Serial.println(r);
 Serial.print ("B = ");
Serial.println(b); */
  switch(color) {
  case 1:
    if(r>value) for(i=r;i>value;i--) {
      rgb(i,g,b);
      delay(time);
