Data from RF to drive stepper motor (Conversion from uint8_t to int)
Hello,
I am using a two SAMD21 Pro RF boards to communicate and drive a stepper motor.
I would like to send 2-digit numbers from one to the other and drive the stepper motor based on the values sent. The code to send and receive RF transmissions works well, but I am having trouble storing the 2-digit number for use on the stepper.
How does one take an input from the serial monitor and store it as an integer??
Errors centered around this part of code:
int in_deg = (char*)buf.toInt()
#include <SPI.h>
//Radio Head Library:
#include <RH_RF95.h>
// Define stepper motor connections and steps per revolution:
#define dirPin 2
#define stepPin 5
#define stepsPerRevolution 200
// We need to provide the RFM95 module's chip select and interrupt pins to the
// rf95 instance below.On the SparkFun ProRF those pins are 12 and 6 respectively.
RH_RF95 rf95(12, 6);
int LED = 4; //Status LED on pin 4
int packetCounter = 0; //Counts the number of packets sent
long timeSinceLastPacket = 0; //Tracks the time stamp of last packet received
// The broadcast frequency is set to 921.2, but the SADM21 ProRf operates
// anywhere in the range of 902-928MHz in the Americas.
// Europe operates in the frequencies 863-870, center frequency at
// 868MHz.This works but it is unknown how well the radio configures to this frequency:
//float frequency = 864.1;
float frequency = 921.2;
  // Declare pins as output:
  pinMode(stepPin, OUTPUT); //stepper
  pinMode(dirPin, OUTPUT); //stepper
  pinMode(LED, OUTPUT);
  SerialUSB.begin(9600);
  // It may be difficult to read serial messages on startup. The following
  // line will wait for serial to be ready before continuing. Comment out if not needed.
  while(!SerialUSB);
  SerialUSB.println("RFM Server!");
  //Initialize the Radio.
  if (rf95.init() == false){
    SerialUSB.println("Radio Init Failed - Freezing");
    while (1);
  else{
  // An LED indicator to let us know radio initialization has completed.
    SerialUSB.println("Receiver up!");
    digitalWrite(LED, HIGH);
    digitalWrite(LED, LOW);
  rf95.setFrequency(frequency);
 // The default transmitter power is 13dBm, using PA_BOOST.
 // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
 // you can set transmitter powers from 5 to 23 dBm:
 // rf95.setTxPower(14, false);
  if (rf95.available()){
    // Should be a message for us now
    uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
    uint8_t len = sizeof(buf);
    int out_deg = in_deg*2;
    if (rf95.recv(buf, &len)){
      digitalWrite(LED, HIGH); //Turn on status LED
      timeSinceLastPacket = millis(); //Timestamp this packet
      SerialUSB.print("Got message: ");
      SerialUSB.print((char*)buf);
      //SerialUSB.print(" RSSI: ");
      //SerialUSB.print(rf95.lastRssi(), DEC);
      SerialUSB.println();
// Messages received, now driving motor to angle provided
      // Set the spinning direction clockwise:
      digitalWrite(dirPin, HIGH);
      //int steps = ((out_deg*10)/360)*stepsPerRevolution ; //this converts degreees input to steps
      // Spin the stepper motor 1 revolution slowly:
      for (int i = 0; i < stepsPerRevolution; i++) {
      // These four lines result in 1 step:
      digitalWrite(stepPin, HIGH);
      delayMicroseconds(2000);
      digitalWrite(stepPin, LOW);
 SerialUSB.print("Motor moved ");
 SerialUSB.println(out_deg);
      // Send a reply
      uint8_t toSend[] = "Got Message!";
      rf95.send(toSend, sizeof(toSend));
      rf95.waitPacketSent();
      SerialUSB.println("Sent a reply");
      digitalWrite(LED, LOW); //Turn off status LED
      SerialUSB.println("Recieve failed");
  //Turn off status LED if we haven't received a packet after 1s
  if(millis() - timeSinceLastPacket > 1000){
    timeSinceLastPacket = millis(); //Don't write LED but every 1s
The easiest approach is to send and receive integers. For example
int16_t n = 1234;
driver.send((uint8_t *)&n, 2);
byte buflen=2;
driver.recv((uint8_t *)&n,&buflen);
in_deg =  atoi((char*)buf);
Worked well for me!
