Hello,
with this processing script below I get the right values into processing from Arduino, but
a. I can't convert the inByte to integer, when I do that I get 0.Why my variable numCol is 0?
b. How can I separate the incoming values for R G B every 3 incoming values?
Any help very appreciated.
import processing.serial.*;
Serial port;
void setup(){
size(45,45);
port = new Serial(this,Serial.list()[1], 9600);
void draw() {
while (port.available() > 0) {
String inByte = port.readStringUntil(10);
if (inByte != null) {
int numCol = int(inByte);
print("in Byte : ");
print(inByte);
println(numCol);
port.clear();
OR why my initial script - reading directly with int variables - does not give me the right values from Serial?
please see the processing code below:
Serial port;
int x=0;
int y=0;
int i=0;
void setup(){
size(45,45);
void draw() {
int inByteRED = port.read();
println("inByteRED");
println(inByteRED);
int inByteGREEN = port.read();
println("inByteGREEN");
println(inByteGREEN);
int inByteBLUE = port.read();
println("inByteBLUE");
println(inByteBLUE);
color c = color(inByteRED, inByteGREEN, inByteBLUE);
//Size of each rectangle with disctinct color
int rectsize=3;
fill(c);
noStroke();
rect(x*rectsize , y*rectsize , rectsize , rectsize);
x++;
if (x > 14) {x = 0; y++;}
if (y > 14) {noLoop();}
