Data from the sensors are not being recorded on to my SD card.
Hello, I recently took over a project that consisted of using an Arduino mega as a data logger. I have various thing connected to the Arduino board such as a
-temp sensor
-"Atlas scientific Lab Grade Dissolved oxygen probe #ENV-40-DOX"
-"Atlas scientific Lab Grade PH Probe #ENV-40-pH"
  • RTC Module (D3231)
  • SD Module
  • LCD Module (16x2)
  • Wifi Module (ESP8266)
I am having an issue wit the data from each sensor not being recorded onto the sd card, could it be possible that the code I was handed over might be wrong? The previous person that put the data logger together told me that The code was running fine before.
The only thing that is recorded on the sd card is this
" Date Time pH DO Water Temp "
I posted the code below, could it be that the way everything is wired up?
Serial.println(pH);
String getData = "GET /update?api_key=" + API + "&" + field + "=" + String(pH);
sendCommand("AT+CIPMUX=1", 5, "OK");
sendCommand("AT+CIPSTART=0,"TCP","" + HOST + ""," + PORT, 15, "OK");
sendCommand("AT+CIPSEND=0," + String(getData.length() + 4), 4, ">");
esp8266.println(getData); delay(1500); countTrueCommand++;
sendCommand("AT+CIPCLOSE=0", 5, "OK");
if (input_string_complete == true)
{ //if a string from the PC has been received in its entirety
Serial2.print(inputstringdo); //send that string to the Atlas Scientific product
Serial2.print('\r'); //add a to the end of the string
inputstringdo = ""; //clear the string
input_string_completedo = false; //reset the flag used to tell if we have received a completed string from the PC
if (sensor_string_completedo == true)
{ //if a string from the Atlas Scientific product has been received in its entirety
Serial.println(sensorstringdo); //send that string to the PC's serial monitor
//uncomment this section to see how to convert the D.O. reading from a string to a float
if (isdigit(sensorstringdo[0]))
{ //if the first character in the string is a digit
DO = sensorstringdo.toFloat(); //convert the string to a floating point number so it can be evaluated by the Arduino
if (DO >= 6.0)
{ //if the DO is greater than or equal to 6.0
Serial.println("high"); //print "high" this is demonstrating that the Arduino is evaluating the DO as a number and not as a string
}//if
if (DO <= 5.99) //if the DO is less than or eq{ ual to 5.99
Serial.println("low"); //print "low" this is demonstrating that the Arduino is evaluating the DO as a number and not as a string
}//if
}//if
Serial.println(DO);
String getDatac = "GET /update?api_key=" + APIII + "&" + field + "=" + String(sensorstringdo);
sendCommand("AT+CIPSEND=0," + String(getDatac.length() + 4), 4, ">");
esp8266.println(getDatac); delay(1500); countTrueCommand++;
sensors.requestTemperatures();
double C = sensors.getTempCByIndex(0);
double F = C * 9 / 5 + 32;
Serial.println(F);
String getDatatwo = "GET /update?api_key=" + API + "&" + fieldb + "=" + String(F);
sendCommand("AT+CIPSEND=0," + String(getDatatwo.length() + 4), 4, ">");
esp8266.println(getDatatwo); delay(1500); countTrueCommand++;
if (!SD.begin(chipSelect))
Serial.println("Card failed, or not present");
// don't do anything more:
return;
}//if
File dataFile = SD.open("datalog.txt", FILE_WRITE);
if (dataFile)
dataFile.println(" ");
dataFile.print(rtc.getDateStr());
dataFile.print(" ");
dataFile.print(rtc.getTimeStr());
dataFile.print(pH);
dataFile.print(DO);
dataFile.print(F);
dataFile.close();
}//if
//else
//Serial.println("OOPS!! SD card writing failed");
lcd.setCursor (0, 0); // go to start of 1nd line
lcd.print("Time: ");
lcd.print(rtc.getTimeStr());
lcd.setCursor (0, 1); // go to start of 2nd line
lcd.print("pH: ");
lcd.print(pH);
lcd.print(" ");
lcd.setCursor (0, 2 ); // go to start of 3nd line
lcd.print("DO: ");
lcd.print(DO);
lcd.setCursor (0, 3); // go to start of 4th line
lcd.print("Water Temp: ");
lcd.print(F);
sensorstring = ""; //clear the string:
sensor_string_complete = false;
sensorstringdo = ""; //clear the string:
sensor_string_completedo = false;
}//loop
void sendCommand(String command, int maxTime, char readReplay[])
Serial.print(countTrueCommand);
Serial.print(". at command => ");
Serial.print(command);
Serial.print(" ");
while (countTimeCommand < (maxTime * 1))
esp8266.println(command);//at+cipsend
if (esp8266.find(readReplay)) //ok
found = true;
}//if
countTimeCommand++;
}//while
if (found == true)
Serial.println("OYI");
countTrueCommand++;
countTimeCommand = 0;
if (found == false)
Serial.println("Fail");
countTrueCommand = 0;
found = false;
}//sendCommand
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SoftwareSerial.h>
#include <SPI.h>
#include <SD.h>
#include <DS3231.h>
#include <LCD.h>
#include <LiquidCrystal.h>
#define RX 10
#define TX 11
#define ONE_WIRE_BUS 5
const int chipSelect = 53;
String inputstring = ""; //a string to hold incoming data from the PC
String sensorstring = ""; //a string to hold the data from the Atlas Scientific product
boolean input_string_complete = false; //have we received all the data from the PC
boolean sensor_string_complete = false; //have we received all the data from the Atlas Scientific product
float pH;
String inputstringdo = "";
String sensorstringdo = "";
boolean input_string_completedo = false;
boolean sensor_string_completedo = false;
float DO;
String AP ="MySpectrumWifif8-2G"; // CHANGE ME
String PASS ="longspark249"; // CHANGE ME
String API = "A7XJSXSGZT9PG7YP"; // CHANGE ME
String APIII = "3LKWE0CQXARPIYKN"; // CHANGE ME
String HOST = "api.thingspeak.com";
String PORT = "80";
String field = "field1";
String fieldb = "field2";
int countTrueCommand;
int countTimeCommand;
boolean found = false;
File dataFile;
SoftwareSerial esp8266(RX, TX);
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DS3231 rtc(SDA, SCL);
#define I2C_ADDR 0x27 // Add your address here.
#define Rs_pin 0
#define Rw_pin 1
#define En_pin 2
#define BACKLIGHT_PIN 3
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR, En_pin, Rw_pin, Rs_pin, D4_pin, D5_pin, D6_pin, D7_pin);
esp8266.begin(9600);
sendCommand("AT", 5, "OK");
sendCommand("AT+CWMODE=1", 5, "OK");
sendCommand("AT+CWJAP="" + AP + "","" + PASS + """, 30, "OK");
Serial3.begin(9600); //set baud rate for software serial port_3 to 9600
Serial2.begin(9600);
inputstring.reserve(10); //set aside some bytes for receiving data from the PC
sensorstring.reserve(30);
sensors.begin();
lcd.begin (20, 4); // our LCD is a 20x4, change for your LCD if needed
// LCD Backlight ON
lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
lcd.setBacklight(HIGH);
lcd.home (); // go home on LCD
rtc.begin();
//#### The following lines can be uncommented to set the date and time for the first time###
rtc.setDOW(TUESDAY); // Set Day-of-Week to SUNDAY
rtc.setTime(21, 30, 30); // Set the time to 12:00:00 (24hr format)
rtc.setDate(7, 5, 2019); // Set the date to January 1st, 2014
return;
}//if
if (dataFile)
//dataFile.println("Date,Time,Temperature,Humidity"); //Write the first row of the excel file
dataFile.print("Date");
dataFile.print("Time");
dataFile.print("pH");
dataFile.print("DO");
dataFile.print("Water Temp");
dataFile.close();
}//if
}//setup
void serialEvent()
//if the hardware serial port_0 receives a char
inputstring = Serial.readStringUntil(13); //read the string until we see a
input_string_complete = true; //set the flag used to tell if we have received a completed string from the PC
}//serialEvent
void serialEvent4()
{ //if the hardware serial port_0 receives a char
inputstringdo = Serial.readStringUntil(13); //read the string until we see a
input_string_completedo = true; //set the flag used to tell if we have received a completed string from the PC
void serialEvent3()
{ //if the hardware serial port_3 receives a char
sensorstring = Serial3.readStringUntil(13); //read the string until we see a
sensor_string_complete = true; //set the flag used to tell if we have received a completed string from the PC
void serialEvent2()
sensorstringdo = Serial2.readStringUntil(13); //read the string until we see a
sensor_string_completedo = true; //set the flag used to tell if we have received a completed string from the PC
delay(1000000);
Serial.print(rtc.getDOWStr());
Serial.print(" ");
Serial.print(rtc.getDateStr());
Serial.print(" -- ");
Serial.println(rtc.getTimeStr());
Serial3.print(inputstring); //send that string to the Atlas Scientific product
Serial3.print('\r'); //add a to the end of the string
inputstring = ""; //clear the string
input_string_complete = false; //reset the flag used to tell if we have received a completed string from the PC
if (sensor_string_complete == true)
Serial.println(sensorstring); //send that string to the PC's serial monitor
//uncomment this section to see how to convert the pH reading from a string to a float
if (isdigit(sensorstring[0]))
pH = sensorstring.toFloat(); //convert the string to a floating point number so it can be evaluated by
if (pH >= 7.0)
{ //if the pH is greater than or equal to 7.0
Serial.println("high"); //print "high" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
}//if
if (pH <= 6.99)
{ //if the pH is less than or equal to 6.99
Serial.println("low"); //print "low" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
}//if
}//if
}//if
Serial2.readStringUntil(13); blocks until it read a CR which means you may miss data on the other Serials
Suggest you use a SafeStringReader and SafeStrings see my tutorials
Text I/O for the Real World and the SafeString tutorial
and How to code Timers and Delays in Arduino
Here is some revised code using SafeStringReader and SafeString
// download SafeString library from Library manager includes SafeStringReader and millisDelay
#include <SafeStringReader.h>  // also includes SafeString.h
#include <millisDelay.h>
#include <SPI.h>
#include <SD.h>
#include <DS3231.h>
#include <LCD.h>
#define RX 10
#define TX 11
createSafeStringReader(inputstring, 80, '\r'); // read until CR can read upto 80 char
createSafeStringReader(sfReader1, 80, '\r'); // read until CR can read upto 80 char
createSafeStringReader(sensorstring, 80, '\r'); // read until CR can read upto 80 char
millisDelay rtcPrintDelay;
float pH;
float DO;
char AP[] = "MySpectrumWifif8-2G"; // CHANGE ME
char PASS[] = "longspark249"; // CHANGE ME
char API[] = "A7XJSXSGZT9PG7YP"; // CHANGE ME
char APIII[] = "3LKWE0CQXARPIYKN"; // CHANGE ME
char HOST[] = "api.thingspeak.com";
char PORT[] = "80";
char field[] = "field1";
char fieldb[] = "field2";
File dataFile;
#define Rs_pin 0
#define Rw_pin 1
#define En_pin 2
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
  SafeString::setOutput(Serial); // show error msgs
  sendCommand("AT+CWJAP=\"" + AP + "\",\"" + PASS + "\"", 30, "OK");
  sensors.begin();
  // LCD Backlight ON
  rtc.begin();
    return;
  }//if
  if (dataFile)
    dataFile.close();
  }//if
  rtcPrintDelay.start(1000000);
  inputstring.connect(Serial);
  sfReader2.connect(Serial2);
  sfReader3.connect(Serial3);
}//setup
  // delay(1000000); evil
  if (rtcPrintDelay.justFinished() ) {
    rtcPrintDelay.repeat();
    Serial.print(" ");
  if (inputstring.read()) { // got the input
    Serial3.print('\r');                                    //add a <CR> to the end of the string
  if (sensorstring.read()) {
    if (sensorstring.toFloat(pH)) {
      // got a valid ph
      // invalid float
      // print error
      Serial.print(sensorstring); Serial.println(" invalid float")
    if (pH >= 7.0)  { //if the pH is greater than or equal to 7.0
    }//if
    if (pH <= 6.99) { //if the pH is less than or equal to 6.99
    }//if
    sensorstring.clear(); // or sensorstring = "";
  }//if
