Data Getting Corrupted.
Hi Their, I hope someone can help me. I am not new to developing but I am new to Arduino’s. I have my self a MEGA 2560, which I am using to build a eight legged robot’s with.
I have Already had some success with this but I have not started wiring the code to allow me to control this robot with a USB wired tether. For the first 7 of my 8 legs this works fine. But my Last leg number 8 things are very strange indeed.
I have my Arduino echo the Byte array that it gets back to the Host Computer. And this array of Data is getting Changed the first 2 bytes in the byte array are altered. I expect to see a 76 , 8 But I get 180, 0. For all other legs it’s working fine it’s just this last leg.
Here is the code that I am using to drive this project.
This is my Arduino code.
#include <Servo.h>
#include <RobotLeg.h>
#include <MyRobot.h>
int MainPowerPin = 2;
MyRobot Bot;
byte Command[10];
boolean Cmd_rec = false;
int idx=0;
int Commandsize=0;
  pinMode(MainPowerPin,OUTPUT);
  digitalWrite(MainPowerPin,LOW);
  Serial.begin(57600);
  Serial.println("Robot- Ready!");
  Bot.AddLeg(39,41,43);
  Bot.AddLeg(45,47,49);
  Bot.AddLeg(51,50,48);
  Bot.AddLeg(46,44,42);
  Bot.AddLeg(53,52,33);
  Bot.AddLeg(36,40,38);
  Bot.AddLeg(31,29,27);
  Bot.AddLeg(34,32,26);
  GetCommand();
  if(Cmd_rec)
    ProcessCommand();
    Serial.write(Command,Commandsize);
    Serial.println("ACK");
boolean GetCommand()
  Cmd_rec = false;
  while (Serial.available() > 0)
    if(idx < 39)
      Command[idx] = Serial.read();
      idx++;
        if(Command[idx-1] == 59) //59 is ';'
          Command[idx] = '\0';
          Commandsize = idx;
          idx = 0;
          Cmd_rec = true;
          return true;
      Serial.println("Debug - Input Error - Input Too Long or No Terminitor Sent!");
      idx = 0;
      return false;
  return false;
void ProcessCommand()
  switch(Command[0])
    case 76:
      //Processing LEg Movement
      Bot.MoveLegPart(Command[1],Command[2],Command[3],Command[4]);
      case 80:
      //Switch Power on to Servo's
        switch (Command[1])
          case 43:
            //ON
            digitalWrite(MainPowerPin,HIGH);
          case 44:
            //OFF
Here is my MyRobot.h File
#ifndef MyRobot_h
#define MyRobot_h
#include <Arduino.h>
#include <../RobotLeg/RobotLeg.h>
enum LegPart
	lp_Hip_V, lp_Hip_H, lp_Knee
class MyRobot
public:
	MyRobot();
	void AddLeg(RobotLeg Leg);
	void AddLeg(int Hip_Hor_Pin, int Hip_Ver_Pin, int Knee_Pin);
	void MoveLegPart(int Legnum,LegPart part, Direction dir, int ammount);
	void MoveLegPart(byte Legnum,byte part, byte dir, byte ammount);
private:
	RobotLeg _legs[7];
	int _leg_count;
#endif
Here is my MyRobot.cpp file
MyRobot::MyRobot()
	_leg_count = 0;
void MyRobot::AddLeg(RobotLeg Leg)
	_legs[_leg_count] = Leg;
	_leg_count++;
void MyRobot::AddLeg(int Hip_Hor_Pin, int Hip_Ver_Pin, int Knee_Pin)
	RobotLeg L;
	L.SetPins(Hip_Hor_Pin,Hip_Ver_Pin,Knee_Pin);
	_legs[_leg_count] = L;
	_leg_count++;
void MyRobot::MoveLegPart(int Legnum,LegPart part, Direction dir, int ammount)
	int res = Legnum % 2;
	switch(dir)
	case UP:
		if(res > 0)
			//left
			ammount = ammount -(ammount * 2);
			//right
	case Down:
		if(res > 0)
			//left
			//right
	switch(part)
	case lp_Hip_V:
		_legs[Legnum - 1].SetHip_V(ammount,Offset);
	case lp_Hip_H:
		_legs[Legnum - 1].SetHip_H(ammount,Offset);
	case lp_Knee:
		_legs[Legnum - 1].SetKnee(ammount,Offset);
void MyRobot::MoveLegPart(byte Legnum,byte part, byte dir, byte ammount)
	Direction D;
	LegPart P;
	int leg = int(Legnum);
	int amt = int(ammount);
	switch (dir)
	case 43:
		D = UP;
	case 45:
		D = Down;
	switch(part)
	case 65:
		P = lp_Hip_V;
	case 66:
		P = lp_Hip_H;
	case 67:
		P = lp_Knee;
	MoveLegPart(leg,P,D,amt);
Here is my RobotLeg.h file
#ifndef RobotLeg_h
#define RobotLeg_h
#include <../Servo/Servo.h>
enum Direction
	UP, Down
enum MoveType
	Extact, Offset
class RobotLeg
public:
	RobotLeg();
	void SetPins(int Hip_Hor_Pin, int Hip_Ver_Pin, int Knee_Pin);
	void SetHip_H(int Angle,MoveType Ty);
	void SetHip_V(int Angle,MoveType Ty);
	void SetKnee(int Angle,MoveType Ty);
private:
	int _Hip_Hor_Angle;
	int _Hip_Ver_Angle;
	int _Knee_Angle;
	int _Delay;
	int _Hip_Hor_Offset;
	int _Hip_Ver_Offset;
	int _Hip_Hor_Pin;
	int _Hip_Ver_Pin;
	int _Knee_Pin;
	Servo _Hip_Hor;
	Servo _Hip_Ver;
	Servo _Knee;
	int AngleCalculator(int cur, int changeammount);
#endif
here is my RobotLeg.ccp file
RobotLeg::RobotLeg()
	int test = 1;
	_Delay = 0;
void RobotLeg::SetPins(int Hip_Hor_Pin, int Hip_Ver_Pin, int Knee_Pin)
	_Hip_Hor_Pin = Hip_Hor_Pin;
	_Hip_Ver_Pin = Hip_Ver_Pin;
	_Knee_Pin = Knee_Pin;
	_Hip_Hor.attach(_Hip_Hor_Pin);
	_Hip_Ver.attach(_Hip_Ver_Pin);
	_Knee.attach(Knee_Pin);
	SetHip_H(90,Extact);
	SetHip_V(90,Extact);
	SetKnee(90,Extact);
void RobotLeg::SetHip_H(int Angle,MoveType Ty)
	switch(Ty)
		case Extact:
			_Hip_Hor_Angle = Angle;
		case Offset:
			_Hip_Hor_Angle =  AngleCalculator( _Hip_Hor_Angle, Angle);
	_Hip_Hor.write(_Hip_Hor_Angle);
void RobotLeg::SetHip_V(int Angle,MoveType Ty)
	switch(Ty)
		case Extact:
			_Hip_Ver_Angle = Angle;
		case Offset:
			_Hip_Ver_Angle = AngleCalculator(_Hip_Ver_Angle , Angle);
	_Hip_Ver.write(_Hip_Ver_Angle);
void RobotLeg::SetKnee(int Angle,MoveType Ty)
	switch(Ty)
		case Extact:
			_Knee_Angle = Angle;
		case Offset:
			_Knee_Angle = AngleCalculator(_Knee_Angle , Angle);
	_Knee.write(_Knee_Angle);
int RobotLeg::AngleCalculator(int cur, int changeammount)
	int res = cur + changeammount;
	if(res < 0)
		return 0;
	if(res > 180)
		return 180;
	return res;
I hope that someone can shed some light on why this is happening.
Sorry for so much code but I do like to work with proper objects.
Thanking you all in advance.
This looks very dangerous:
byte Command[10];
  Cmd_rec = false;
    if(idx < 39)
      idx++;
Dangerous how ?
Apart from me not reflecting the change to the Command array size in the if statement ???
In MyRobot.h
RobotLeg _legs[7];
How many legs did you say your robot had ?
ToxicBlotch: Dangerous how ?
You check if there is at least 1 character in the buffer, and then read all 39 at them.
Arrch:
That's not what that code says to me... That says "while there are characters available, and I have read no more than 39 of them, add them into the Command array".
majenko:
Arrch:
You're right, I read it wrong.
majenko:
Arrch:
It's still putting 39 characters plus null terminator in a 10-character array.
WizenedEE:
majenko:
Arrch:
Yes, but the OP is already aware of that:
UKHeliBob: In MyRobot.h
RobotLeg _legs[7];
Cheers UKHeliBob nice simple Error that was just completely Eluding me :(
But it looks like theirs a bigger problem with my code that just a badly sized Array :(
Yes, there are two badly sized arrays. Take another look at WizenedEE's latest post.
