Data in Serial Monitor Displays Incorrectly
Hi all,
I'm trying to do something basic which I thought would work. I currently just want to enter data into the Serial monitor and have it printed after the user does so. The code works to wait for data, but the Serial.print to display it afterwards appears to display garbage.
For example, when I enter "5", it outputs "53.00" or something like that.
What could be going on?
/*Calculate the hypotenuse of a triangle.
* User shall input 2 sides of the triangle.
* References:
*	https://www.tutorialspoint.com/c_standard_library/math_h.htm
#include<Arduino.h>
#include<math.h>
//using namespace std;
	//variables
	double side1;
	int side2;
	double hypotenuse;   // hypotenuse
	Serial.println("Let's calculate the hypotenuse of a triangle.");
  Serial.print("Enter side 1...");
  while (Serial.available() == 0)
  {// waits until data is entered into serial monitor
  side1 = Serial.read();
  Serial.print("\nSide 1 = ");
  Serial.println(side1);
  Serial.flush();
  delay(3000);
  exit(0);
side1 is a double
read() reads a byte - 53 is the ASCII character code for character 5
try
side1=Serial.parseFloat()
That worked well, thank! I tried a bit more in my code, but it's skipping on waiting for side2 around here:
 Serial.print("\nEnter side 2...");
It just goes to end of program, prints side1, but misses side 2.
Any ideas why it's not waiting like it did the first time?
* References:
        https://www.programmingelectronics.com/parseint/
#include<Arduino.h>
#include<math.h>
	//variables
	double side1;
	int side2;
  side1 = Serial.parseFloat();    //takes incoming characters and converts it to a number. This is read into the buffer altogether.  Default is data type long.
  Serial.flush();
  side2 = Serial.parseFloat();
  // print data
  Serial.print("\nSide 2 = ");
  Serial.println(side2);
  Serial.flush();
  delay(3000);
  exit(0);
Serial.flush() flushes the output stream not the input so the newline is left in the input buffer
try
  while(Serial.available()) Serial.read();   // flush input
have a read of Serial input basics
I tried the code as you specified, and made a small edit to it based on the link you provided. It still didn't work (neither way did).
However, I noticed that after I typed in the 1st side, e.g. "5", if I hit another number almost immediately, the program worked.
But it does not "hang" for the 2nd side to be entered, as it's supposed to.
* References:
  https://forum.arduino.cc/t/serial-input-basics-updated/382007
#include<Arduino.h>
#include<math.h>
	//variables
	double side1;
	double side2;
  //Serial.flush();
  { Serial.read();    // flush input buffer
  // print data
  Serial.flush();
  delay(3000);
  exit(0);
Your forgot to add this before the entry for side2 like you did wiyh side1
I tried that too, and it didn't work either.
Side2 code:
//while(Serial.available())
Full code:
* References:
#include<Arduino.h>
#include<math.h>
	//variables
	double side1;
	double side2;
  //Serial.flush();
  // print data
  Serial.flush();
  delay(3000);
  exit(0);
You need to read your code more carefully.
You have a line which waits for Serial input.
You have a line which reads the input from Serial and assigns it to a variable.
Finally you have code which empties the input buffer.
If this was what you wanted for side1, then you should be able to duplicate it for side2.
I got it now, thanks. I needed to include the flush buffer before asking for input again between side1 and side2.
* References:
#include<Arduino.h>
#include<math.h>
	//variables
	double side1;
	double side2;
// Side 1
  while (Serial.available() == 0)   // waits until data is entered into serial monitor
// flush input buffer, do before asking for new input.  Notes: https://forum.arduino.cc/t/serial-input-basics-updated/382007
  while (Serial.available() > 0)
// Side 2
// print data
  Serial.print("Side 2 = ");
  Serial.flush();   //empty serial buffer output
  exit(0);          // ends program
