I am running this code
// general constants
#define startButton 8
#define stopButton 9
#define DEBUG true
// general global variables
unsigned long start = 0.0;
unsigned long finished = 0.0;
unsigned long elapsed = 0.0;
// forward declarations
// output calculation results
void displayResult();
// start Serial
// tell 'em who we are, man
Serial.println("Stopwatch.ino");
// initialize buttons
pinMode(startButton, INPUT);
pinMode(stopButton, INPUT);
digitalWrite(startButton, LOW);
digitalWrite(stopButton, LOW);
} // end setup()
// give instructions
Serial.println("Press left button for Start/Reset");
Serial.println("Press right button for elapsed time");
if (digitalRead(startButton) == HIGH)
if (DEBUG) Serial.println("startButton was HIGH");
start = millis();
finished = 0.0;
delay(200); // debounce
Serial.println("Started ...");
if (DEBUG) digitalWrite(startButton, LOW);
if (digitalRead(stopButton) == HIGH);
if (DEBUG)Serial.println("stopButton was HIGH");
finished = millis();
displayResult();
if (DEBUG) digitalWrite(stopButton, LOW);
if (DEBUG) delay(2000);
} // end loop()
// local variables
float h, m, s, ms;
unsigned long over;
// get elapsed
elapsed = finished - start;
// calculate time elements
h = int(elapsed / 3600000);
over = elapsed % 3600000;
m = int(over / 60000);
over = over % 60000;
s = int(over / 1000);
ms = over % 1000;
// display time elements
Serial.print("Raw elapsed time: ");
Serial.print(elapsed);
Serial.println(": ms");
Serial.print("Elapsed time: ");
Serial.print(h, 0);
Serial.print("h ");
Serial.print(m, 0);
Serial.print("m ");
Serial.print(s, 0);
Serial.print(" s ");
Serial.print(ms, 0);
Serial.println("ms");
} // end displayResult()
on this layout
My problem is that the stopButton is permanently high (even when the power lead is disconnected from the stopButton)
Started ...
stopButton was HIGH
Raw elapsed time: 401: ms
Elapsed time: 0h 0m 0 s 401ms
stopButton was HIGH
Raw elapsed time: 2635: ms
Elapsed time: 0h 0m 2 s 635ms
stopButton was HIGH
Raw elapsed time: 4870: ms
Elapsed time: 0h 0m 4 s 870ms
stopButton was HIGH
Raw elapsed time: 7104: ms
Elapsed time: 0h 0m 7 s 104ms
When I put a DMM across it the stopSwitch is HOT when button pressed and COLD when not. Video confirmation at Youtube.
The start button behaves itself.
How do I get the stopButton to go LOW when the button is not pressed?
Thanks
