Data input via serial UART
I am building a small project where I need to test performance under different conditions, I want to be able to change a integer value in my sketch by inputting the value on the laptop connected via the UART. I have written this;
char c;
if (Serial.available())
  c = Serial.read();
Serial.println(c); //for testing
delay(500);  //for testing
Which seems to work, and holds the numbers 1 - 9 OK as a Char, however I need this number as a integer to integrate into other calculations. Is there an easy way to either return an integer value instead of Char, or, convert the Char to an int?
int n = c - '0';
For one digit numbers, that works.
PaulS:
int n = c - '0';
Thanks Paul (again!)
