I've devised a basic setup running an SD card shield to retrieve a number stored in a text file on the SD card, and use it as the rate at which a statement will be written to the SD card in a .csv file.
However, let alone writing the statement to the .csv file, even the task to retrieve the number from the text file fails. Both the processes don't work, and the else flag statements are triggered.
Here's the code:-
#include <SD.h>
//Set by default for the SD card library
//MOSI = pin 11
//MISO = pin 12
//SCLK = pIN 13
//We always need to set the CS pin
const int CS_PIN =10;
const int POW_PIN =8;
//Default rate of 5 seconds
int refresh_rate = 5000;
Serial.println("Initializing Card");
//CS pin is an output
pinMode(CS_PIN, OUTPUT);
//Card will draw power from pin 8, so set it high
pinMode(POW_PIN, OUTPUT);
digitalWrite(POW_PIN, HIGH);
if (!SD.begin(CS_PIN))
Serial.println("Card Failure");
return;
Serial.println("Card Ready");
//Read the configuration information (speed.txt)
File commandFile = SD.open("ID.txt");
if (commandFile)
Serial.println("Reading Command File");
while(commandFile.available())
refresh_rate = commandFile.parseInt();
Serial.print("Refresh Rate = ");
Serial.print(refresh_rate);
Serial.println("ms");
commandFile.close(); // close the file when finished
Serial.println("Could not read command file.");
return;
File datafile=SD.open("log.csv");
if(datafile)
datafile.println("Adeel is cool");
datafile.close();
Serial.println("Write successful!");
Serial.println("You're a failure at life.");
delay(refresh_rate);
While the SD card initialization process is successful, neither the reading nor writing processes work.
What seems to be the problem? I've doublechecked my wirings and the code as well, and yet, nothing suffices.
