Data Logger Code
Hey guys, I'm making a data logger with a Nano Every. I have a BME280, a thermometer, a mic, and a Deek-Robot data logging shield (8105). I have everything working separately, but I can't seem to get it working when I try to put it all together. And to clarify, I do not mean physically, just in code.
Each section of code works separately, like the RTC will output correctly, or I can read and write to the sd card, or get the data from the BME280 in the serial output. I just can't get them to work nicely with each other.
I'd like to point out that I have absolutely no idea what I'm doing, and I did not write any of this code myself. However, I need to finish this project as I need to deploy it in real world scenarios quite soon.
I would also like some advice on putting the Nano to sleep for about 30 minutes or so in between each log, as this thing will be out in the wild for months at a time and needs to be ultra power saving when not in use, supplemented a bit by a solar panel.
Here is the code that I have Frankenstein'd together:
int ThermistorPin = A2;
int Vo;
float R1 = 10000;
float logR2, R2, T;
float c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
const int sampleWindow = 50;  // Sample window width in mS (50 mS = 20Hz)
int const AMP_PIN = A6;       // Preamp output pin connected to A0
unsigned int sample;
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <RTClib.h>
#include <SD.h>
#define BME_SCK 6
#define BME_MISO 3
#define BME_MOSI 5
#define BME_CS 4
#define DS1307_I2C_ADDRESS 0x68
RTC_DS1307 rtc;
File myFile;
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK); // software SPI
    while(!Serial);    // time to get serial running
    unsigned status;
    status = bme.begin();
    printTime();
    printValues();
    printSound();
void printValues() {
  myFile = SD.open("data.txt", FILE_WRITE);
    myFile.print("Temperature = ");
    myFile.print(bme.readTemperature());
    myFile.println(" °C");
    myFile.print("Pressure = ");
    myFile.print(bme.readPressure() / 100.0F);
    myFile.println(" hPa");
    myFile.print("Approx. Altitude = ");
    myFile.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
    myFile.println(" m");
    myFile.print("Humidity = ");
    myFile.print(bme.readHumidity());
    myFile.println(" %");
    myFile.print("Temperature: ");
    myFile.print(T);
    myFile.println(" F");
  myFile.close();
void printTime() {
   DateTime time = rtc.now();
 //Full Timestamp
 myFile.println(String("DateTime::TIMESTAMP_FULL:\t")+time.timestamp(DateTime::TIMESTAMP_FULL));
void printSound() {
    unsigned long startMillis = millis(); // Start of sample window
  unsigned int peakToPeak = 0;   // peak-to-peak level
  unsigned int signalMax = 0;
  unsigned int signalMin = 1024;
  // collect data for 50 mS and then plot data
  while (millis() - startMillis < sampleWindow)
    sample = analogRead(AMP_PIN);
    if (sample < 1024)  // toss out spurious readings
      if (sample > signalMax)
        signalMax = sample;  // save just the max levels
      else if (sample < signalMin)
        signalMin = sample;  // save just the min levels
  peakToPeak = signalMax - signalMin;  // max - min = peak-peak amplitude
  myFile.println();
  myFile.println(peakToPeak);
  //double volts = (peakToPeak * 5.0) / 1024;  // convert to volts
  //Serial.println(volts);
    Vo = analogRead(ThermistorPin);
  R2 = R1 * (1023.0 / (float)Vo - 1.0);
  logR2 = log(R2);
  T = (1.0 / (c1 + c2*logR2 + c3*logR2*logR2*logR2));
  T = T - 273.15;
  T = (T * 9.0)/ 5.0 + 32.0;
    myFile.close();
I got working code from the RTClib > timestamp example, the SD > ReadWrite example, and various sources across the internet and this forum for the other pieces.
Just to be ultra clear, this is not a hardware or wiring issue at all. It is only when I try to put the code together that anything fails.
Here is what it looks like if anyone is curious or needs to see for anything
Thank you guys so much in advance for your help!
You are making the usual mistake of adding everything together at once, without a clear organizational plan. Experienced people recommend to start with working code, like writing data to an SD card, and adding one feature to it at a time, debugging as you go.
The SD card libraries have basic logging examples that you should study, making sure that you understand what each line does. Then add code to read for example the temperature sensor, and make sure you can log those data to a file and recover the data afterwards.
Repeat until all the pieces are working together, one step at a time.
Finally, log file organization must be planned in advance, so that it is easy to read back, knowing which bit of data is which.
You should also start looking at your components to be sure they will work in the environment you will be placing them. If not you will need to figure out how to house them so they stay comfortable. Also you will need to study your battery specifications as it needs to hold a charge for a long time and work in temperature extremes.
how are you powering the system?
upload a schematic?
