Hello everyone,
I am using an Uno to collect data. I want to be able to write this data to an SD card and have the name of the file to have a number associated with the test after each power cycle. (Power on: test_001. Power off then power on again: test_002 etc) I found some code on a SparkFun forum that does this pretty well and I have been able to modify it successfully… for the most part. I’m wanting to name the files with initials, a four digit number, an underscore, then the 2 digit trial number, for example: XX1234_00
The code throws an error if my file name exceeds 6 characters. I can remove one letter, one number or the underscore and the code works fine. Is there a quick fix to allow a longer file name? I have already tried increasing “char filename[16]” to [32] [64] etc. but no luck.
I will include the original code as well as what I have modified. Any help would be much appreciated!
Original:
#include <SD.h>
const int chipSelect = 10;
char filename[16];
Serial.begin(9600); // Open serial communications and wait for port to open:
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
//char filename[16]; // make it long enough to hold your longest file name, plus a null terminator
int n = 0;
snprintf(filename, sizeof(filename), "data%03d.txt", n); // includes a three-digit sequence number in the file name
while(SD.exists(filename)) {
n++;
File dataFile = SD.open(filename,FILE_READ);
Serial.println(n);
Serial.println(filename);
dataFile.close();
//now filename[] contains the name of a file that doesn't exist
File dataFile = SD.open(filename, FILE_WRITE);
if (dataFile) {
int sensorValue = analogRead(A0);
float voltage = sensorValue * (5.0/1023.0);
Serial.println(voltage);
dataFile.println("teste");
dataFile.println(voltage);
dataFile.close();
else {
Serial.println("error");
Modified:
#include <SD.h>
//initialize pins for SD shield
char filename[16];
//initialize pins for sensors
int sensor1Pin = 0;
int sensor2Pin = 1;
int sensor3Pin = 2;
int sensor4Pin = 3;
//manually input desired filename here before each test
char *s = "TR3035_";
return;
int n = 0;
snprintf(filename, sizeof(filename), "%s%02d.txt", s, n); // includes a two-digit sequence number in the file name
n++;
Serial.println(n);
dataFile.close();
if (dataFile) {
float sensorVal[] = {0, 0, 0, 0};
//read sensor values
sensorVal[0] = analogRead(sensor1Pin);
sensorVal[1] = analogRead(sensor2Pin);
sensorVal[2] = analogRead(sensor3Pin);
sensorVal[3] = analogRead(sensor4Pin);
//print values to the serial monitor
Serial.print(sensorVal[0]);
Serial.print(",");
Serial.print(sensorVal[1]);
Serial.print(",");
Serial.print(sensorVal[2]);
Serial.print(",");
Serial.println(sensorVal[3]);
//print values to data file
dataFile.print(sensorVal[0]);
dataFile.print(",");
dataFile.print(sensorVal[1]);
dataFile.print(sensorVal[2]);
dataFile.println(sensorVal[3]);
dataFile.close();
else {
delay(10);
