Thanks for your speedy response! Here are some sample data:
data.csv
2013,4,6,17,45,0,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.59,0.1,26.67,79.99,24.38,79.99,24.57,76.22,26.19,79.14,21,7,167
2013,4,6,17,45,3,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.59,0.1,26.67,79.99,24.32,79.99,24.57,76.22,26.7,78.92,22,7,183
2013,4,6,17,45,7,0.52,0.51,0.0,0.0,0.52,0.36,0.14,0.51,2.59,0.1,26.67,79.99,24.32,79.99,24.51,76.11,26.7,78.92,21,7,167
2013,4,6,17,45,11,0.52,0.51,0.0,0.0,0.52,0.36,0.14,0.51,2.59,0.1,26.67,79.99,24.32,79.99,24.57,76.22,26.1,78.81,21,7,167
2013,4,6,17,45,15,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.59,0.1,26.67,79.99,24.32,79.99,24.57,76.22,26.1,78.81,21,7,167
2013,4,6,17,45,19,0.52,0.51,0.0,0.0,0.52,0.36,0.14,0.51,2.59,0.1,26.67,79.99,24.38,79.99,24.57,76.22,26.1,78.81,21,7,167
2013,4,6,17,51,18,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,26.13,79.3,23,8,174
2013,4,6,17,51,22,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.32,79.99,24.57,76.22,26.7,78.92,23,8,174
2013,4,6,17,51,26,0.52,0.51,0.0,0.0,0.52,0.36,0.14,0.51,2.60,0.1,26.67,79.99,24.32,79.99,24.57,76.22,26.1,78.81,23,8,174
2013,4,6,17,51,30,0.52,0.51,0.0,0.0,0.52,0.36,0.14,0.51,2.60,0.1,26.67,79.99,24.32,79.99,24.57,76.22,26.1,78.81,23,8,174
2013,4,6,17,51,34,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.32,79.99,24.57,76.22,26.1,78.81,23,8,174
2013,4,6,17,51,38,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.32,79.99,24.57,76.22,25.94,78.69,23,8,174
2013,4,6,17,51,41,0.52,0.51,0.0,0.0,0.52,0.36,0.14,0.51,2.60,0.1,26.67,79.99,24.32,79.99,24.63,76.33,25.94,78.69,23,8,174
2013,4,6,17,51,45,0.52,0.51,0.0,0.0,0.52,0.36,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.94,78.69,23,8,174
2013,4,6,17,51,49,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.32,79.99,24.57,76.22,25.94,78.69,23,8,174
2013,4,6,17,51,53,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.32,79.99,24.57,76.22,25.88,78.58,23,8,174
2013,4,6,17,51,57,0.52,0.51,0.0,0.0,0.52,0.36,0.14,0.51,2.60,0.1,26.67,79.99,24.32,79.99,24.57,76.22,25.88,78.58,23,8,174
2013,4,6,17,52,1,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.88,78.58,23,8,174
2013,4,6,17,52,5,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.88,78.58,23,8,174
2013,4,6,17,52,8,0.52,0.51,0.0,0.0,0.52,0.36,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.88,78.58,23,8,174
2013,4,6,17,52,12,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.88,78.58,23,8,174
2013,4,6,17,52,16,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.88,78.58,23,8,174
2013,4,6,17,52,20,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.88,78.58,24,8,191
2013,4,6,17,52,24,0.52,0.51,0.0,0.0,0.52,0.36,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.82,78.47,23,8,174
2013,4,6,17,52,28,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.82,78.47,24,8,191
2013,4,6,17,52,32,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.82,78.47,24,8,191
2013,4,6,17,52,35,0.52,0.51,0.0,0.0,0.52,0.36,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.82,78.47,24,8,191
2013,4,6,17,52,39,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.82,78.47,23,8,174
2013,4,6,17,52,43,0.52,0.51,0.0,0.0,0.52,0.37,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.82,78.47,24,8,191
2013,4,6,17,52,47,0.52,0.51,0.0,0.0,0.52,0.36,0.14,0.51,2.60,0.1,26.67,79.99,24.38,79.99,24.57,76.22,25.82,78.47,24,8,191
I guess I kind of simplified my descriptions a bit. The first 6 values are date and time, the next 8 are current, then voltage, power in kW, temp1_c, temp1_f, temp2_c, temp2_f, temp3_c, temp3_f, temp4_c, temp4_f, the last three represent UV, visible light and IR index. New data come in every 3-4 seconds and it will go on 24/7, and I want to keep the data for at least a year. I want to be able to select x and y axis as whatever variable I want, so I think the site needs to be able to go to the SD card, get its data from an ever growing data file, and plot the data. Can the Arduino with ethernet shield do that? Thanks!
I am also kind of confused about the ethernet shield. The site says that we can't use both the SD slot and w5100 at the same time. So I am not sure if it is capable of reading data from the SD card and present the data on the website at the same time...
