I am very new to Arduino but I would love to build a temperture data logger and was wondering if anyone out there has done this already or has some tips on how it might be done?
Cheers.
Cheers.
Hello and welcome!
Divide this problem into multiple sections:
Read the temperature sensor
Convert the reading into a celcius/farenheit degree
Store multiple data
In an array
In EEPROM
Do actions at a set interval
This is probably not a complete list of things that needs to be solved, but it should get you going. ![]()
I have done a simple temperature "monitor"
Hi AlphaBeta & Eried,
Thanks for the info, much appreciated and good to know it's possible ![]()
What I need to do now is figure out how to do the following:
I have ordered a book - lets see how it goes ![]()
This could make for a popular sheild to data log all sorts of info: temperature, humidity, light, voltage, current, CO2, etc although this is beyond my abilities :-[
I think point5 is right, a hardware shield is needed for a good data logger.
I started by writing new libraries for SD read/write. The first is a FAT16 library Google Code Archive - Long-term storage for Google Code Project Hosting..
The second is part of a library to record sound. The folder SdFat in this applications, Google Code Archive - Long-term storage for Google Code Project Hosting. is a general purpose FAT16/FAT32 library for SD cards.
There are example showing how to write analogRead value with both libraries.
Much hardware and software support is required for a true data logger.
I have been building a prototype data logger with some features I think are needed using an Adafruit Proto Shield. It has a quad precision op-amp with programmable gain to prevent channel crosstalk and set the gain, a precision voltage reference, and a real time clock.
It records to a microSD. It will be controlled and configured by a file.
Here are two products I am using:
MicroSD card module with level shifters MicroSD Card Adapter
Real time clock module http://www.sparkfun.com/commerce/product_info.php?products_id=99
I used a SOIC TLV2374 op-amp. It is a precession amp with CMOS inputs designed for use with high-impedance sensor interfaces.
I am still playing with the voltage reference.
Also you need some decent terminal blocks to connect external devices.
A good set of requirements would be helpful. 4-20ma current loop support? More than 0-5 volt? Data rates? Time stamps? Calibration? The list is endless.
Hi wgreiman,
Just wondering how you're getting on with your data logger project - I'm making some progress but still a long way to go!!!
