Data Logging from Multiple Boards to HDD
:cold_sweat:
I was trying to store sensor data from multiple Arduino bords to one text file with Processing Programming Language V2.1.1.
  1. I can read and store the data as a text file from a Arduino board with the program shown below. It works fine.
  2. I wanted to read data from multiple boards and record in one text file. I saved this program with a different name and made some chnages. It stopped working. I compared line by line with the working program and deleted the chages, still it did not work.
  3. I was surprised to see that even an insignificant change makes the program unworkable. Even if I comment-out the line, the program does not work any more. It is explained below.
To_Txt_No_Dgtl.pde
*** WARNING: ANY FILE WITH TODAY’S DATE WILL BE OVERRITTEN ****
  • Receive Multiple Fields Binary To File_P
  • portIndex must be set to the port connected to the Arduino
  • based on ReceiveMultipleFieldsBinary, this version saves data to file
  • Press any key to stop logging and save file
import processing.serial.*;
PrintWriter output;
String fileNm;
String prtNm;
Serial myPrt, myPrt1; // Create object from Serial class
short prtIndx = 2; // select the com port, 0 is the first port
char HEADER = β€˜H’;
int TtlPrt = 0;
int strtng, dy = 0;
int val;
String y, m, d;
String hr;
String mn;
String s;
String t;
size(200, 200);
dy = day();
TtlPrt = Serial.list().length; // Counts how many com ports are present
if (TtlPrt <=2) // i.e. Arduino is connected or not
println(β€œOnly " + TtlPrt + " COM ports are present.”);
println(β€œMay be, Arduino is not connected.”);
// Open whatever serial port is connected to Arduino.
String prtNm = Serial.list()[prtIndx];
println(Serial.list());
println(" Connecting to β†’ " + Serial.list()[prtIndx]);
myPrt1 = new Serial(this, prtNm, 9600);
void draw()
if (TtlPrt <=2)
exit();
{ // After running, for the first time a file is created
if (strtng == 0 || dy != day())
y = str(year());
m = str(month());
d = str(day());
if (month() < 10)
m = β€œ0” + m;
if (day() < 10)
d = β€œ0” + d;
if (dy != day()) // When continuosly running, if the date changes the existing file is closed and a new file is created
output.flush(); // Writes the remaining data to the file
output.close(); // Closes the file
fileNm = (y + m + d);
output = createWriter(fileNm + β€œ.txt”);
output.println(" , " + " , " + " , " + "Room, " + " Roof, " + "S.Wall, " + "S.Wall, " + " Roof, " + "E.Wall ");
output.println("Hr, " + "Mn, " + "Sec, " + "Centre, " + " under, " + "inside, " + "otside, " + " top, " + "outside " + β€œ\n”);
strtng = 1;
dy = day();
hr = str(hour());
mn = str(minute());
s = str(second());
if (hour() < 10)
hr = β€œ0” + hr;
if (minute() < 10)
mn = β€œ0” + mn;
if (second() < 10)
s = β€œ0” + s;
if ( myPrt1.available() >= 15) // wait for the entire message to arrive
if( myPrt1.read() == HEADER) // is this the header
// header found
println(hr + " " + mn + " " + s + " ");
output.print(hr + ", " + mn + ", " + s + ", ");
// --------- print the six analog port values ---------
for(int i=0; i < 6; i ++)
val = 0;
val = readArduinoInt1();
println("analog port " + i + β€œ= " + val);
if (val <= 9)
output.print(” " + val + ", β€œ);
if (val > 9 && val < 100)
if (val > 99 && val < 1000)
output.print(” " + val + β€œ, β€œ);
if (val > 999 && val < 10000)
if (val > 9999 && val < 100000)
println(”----”);
output.println(”\n”);
k = k+1;
if (k > 10)
k=0;
void keyPressed()
output.close(); // Finishes the file
exit(); // Stops the program
// ------- Function for value reading from COM2 ----------
// return the integer value from bytes received on the serial port
// (in low,high order)
int readArduinoInt1()
int val; // Data received from the serial port
val = myPrt1.read(); // read the least significant byte
val = myPrt1.read() * 256 + val; // add the most significant byte
return val;
  1. The β€œif-then” loop from line 101 to 130 works fine.
  2. But, if I add an β€œelse” loop the working loop stops working as shown below:
Working codes
println(β€œPort is not available”);
Note: The curly brackets are not necessary, as it is only one line after β€œelse”.
The idea of this program was adopted from Arduino Cookbook by Michael Margolis.
How do you have multiple boards connected to one serial port on the PC?
