Data logging on water flow meter project
I have a brass valve flow meter connected to a Nano with bluetooth transmitting to a mobile ios app.
Currently the code transmits data in real time but I'd like to make sure I have the last data saved in case the unit hangs or something. I'm wondering how to go about that?
Here is the code:
Liquid flow rate sensor -DIYhacking.com Arvind Sanjeev
Measure the liquid/water flow rate using this code.
Connect Vcc and Gnd of sensor to arduino, and the
signal line to arduino digital pin 2.
//BLE
//include <SPI.h> and <ble.h>
//setup()SPI.setDataMode,setBitOrder, setClockDivider, begin(), ble_begin
//ifble_connected() while ble_available(), ble_read() or ble_write()
byte statusLed    = 13;
byte sensorInterrupt = 0;  // 0 = digital pin 2
byte sensorPin       = 2;
// The hall-effect flow sensor outputs approx 4.5 pulses/sec/litre/min of flow.
float calibrationFactor = 4.5;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
void setup(){
  // Initialize a serial connection for reporting values to the host
  // Set up the status LED line as an output
  pinMode(statusLed, OUTPUT);
  digitalWrite(statusLed, HIGH);  // We have an active-low LED attached
  pinMode(sensorPin, INPUT);
  digitalWrite(sensorPin, HIGH);
  pulseCount        = 0;
  flowRate          = 0.0;
  flowMilliLitres   = 0;
  totalMilliLitres  = 0;
  oldTime           = 0;
  // The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
  // Configure to trigger on a FALLING state change (transition from HIGH
  // state to LOW state)
  attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
 * Main program loop
void loop(){
   if((millis() - oldTime) > 5000) {   // Only process counters once per second
    // Disable the interrupt while calculating flow rate and sending the value to
    // the host
    detachInterrupt(sensorInterrupt);
    // Because this loop may not complete in exactly 1 second intervals we calculate
    // the number of milliseconds that have passed since the last execution and use
    // that to scale the output. We also apply the calibrationFactor to scale the output
    // based on the number of pulses per second per units of measure (litres/minute in
    // this case) coming from the sensor.
    flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
    // Note the time this processing pass was executed. Note that because we've
    // disabled interrupts the millis() function won't actually be incrementing right
    // at this point, but it will still return the value it was set to just before
    // interrupts went away.
    oldTime = millis();
    // Divide the flow rate in litres/minute by 60 to determine how many litres have
    // passed through the sensor in this 1 second interval, then multiply by 1000 to
    // convert to millilitres.
    flowMilliLitres = (flowRate / 60) * 1000;
    // Add the millilitres passed in this second to the cumulative total
    totalMilliLitres += flowMilliLitres;
    unsigned int frac;
    // Print the flow rate for this second in litres / minute
    //Serial.print("Flow rate: ");
    //Serial.print(int(flowRate));  // Print the integer part of the variable
    //Serial.print(".");             // Print the decimal point
    // Determine the fractional part. The 10 multiplier gives us 1 decimal place.
    frac = (flowRate - int(flowRate)) * 10;
    //Serial.print(frac, DEC) ;      // Print the fractional part of the variable
    //Serial.print("L/min");
    // Print the number of litres flowed in this second
    //Serial.print("  Current Liquid Flowing: ");             // Output separator
    //Serial.print(flowMilliLitres);
    //Serial.print("mL/Sec");
    // Print the cumulative total of litres flowed since starting
    //Serial.print("  Output Liquid Quantity: ");             // Output separator
    //Serial.print(totalMilliLitres);
    //Serial.println("mL");
    //Send data over BLE
    sendOverBLE();
    // Reset the pulse counter so we can start incrementing again
    pulseCount = 0;
    // Enable the interrupt again now that we've finished sending output
Insterrupt Service Routine
void pulseCounter(){
  // Increment the pulse counter
  pulseCount++;
///////ble send
void sendOverBLE() {
  int mystring;
  mystring = int(totalMilliLitres);
//  if (Serial.available() > 0)  {
//    Serial.println(mystring);//send what has been received
//    Serial.println();   //print line feed character
  //Sometimes I get null in the BlunoTerminal ap and I must open the Serial Monitor
  //in order to get the valid data across...How would I do this in the app?
  //Serial.flush();
