I am new to arduino. I have built a C02 sensor using info. from the link below:
http://www.osbss.com/tutorials/co₂-sensor/
The code is producing no errors (now!) and the SD card being used is a new SanDisk MicroSD 16gb card. [These are supplied formatted so I have not followed the advise given in the sticky.] Having put the card into the MacBook no files were found/seen. The C02 sensor light was flashing showing C02 was being sensed by the green LED was flashing 3 times indicating an issue to with the card.
I will post the code below. Please could you take a look? I have checked the pins. I am wondering what other checks can be done to try to find the problem.
Many thanks.
// OSBSS CO2 data logger based on SenseAir K-30 1% CO2 sensor
// Communication with sensor using I2C protocol
// Last edited on May 29, 2015 - old SdFat code
#include <EEPROM.h>
#include <DS3234lib3.h>
#include <PowerSaver.h>
#include <Wire.h>
#include <SdFat.h>
// Launch Variables ******************************
long interval = 5; // set logging interval in SECONDS, eg: set 300 seconds for an interval of 5 mins
int dayStart = 8, hourStart = 16, minStart = 30; // define logger start time: day of the month, hour, minute
char filename[15] = "output.csv"; // Set filename Format: "12345678.123". Cannot be more than 8 characters in length, contain spaces or begin with a number
// Global objects and variables ******************************
PowerSaver chip; // declare object for PowerSaver class
DS3234 RTC; // declare object for DS3234 class
SdFat sd; // declare object for SdFat class
SdFile file; // declare object for SdFile class
#define POWER 3 // pin 3 supplies power to microSD card breakout
#define LED 7 // pin 7 controls LED
int SDcsPin = 9; // pin 9 is CS pin for MicroSD breakout
int CO2ppm = 0;
int _CO2ppm;
// ISR ****************************************************************
ISR(PCINT0_vect) // Interrupt Vector Routine to be executed when pin 8 receives an interrupt.
//PORTB ^= (1<<PORTB1);
asm("nop");
// setup ****************************************************************
Serial.begin(19200); // open serial at 19200 bps
pinMode(LED, OUTPUT); // set output pins
pinMode(POWER, OUTPUT);
digitalWrite(POWER, HIGH); // turn on SD card
delay(1); // give some delay to ensure RTC and SD are initialized properly
Wire.begin(); // initialize I2C using Wire.h library
if(!sd.begin(SDcsPin, SPI_FULL_SPEED)) // initialize SD card on the SPI bus
// if ('a' == 'b')
delay(10);
SDcardError();
delay(10);
//Serial.println("inside else block from setup");
file.open(filename, O_CREAT | O_APPEND | O_WRITE); // open file in write mode and append data to the end of file
delay(1);
String time = RTC.timeStamp(); // get date and time from RTC
file.println();
file.print("Date/Time,CO2(ppm)"); // Print header to file
file.println();
PrintFileTimeStamp();
file.close(); // close file - very important
// give some delay by blinking status LED to wait for the file to properly close
digitalWrite(LED, HIGH);
delay(10);
digitalWrite(LED, LOW);
RTC.checkInterval(hourStart, minStart, interval); // Check if the logging interval is in secs, mins or hours
RTC.alarm2set(dayStart, hourStart, minStart); // Configure begin time
RTC.alarmFlagClear(); // clear alarm flag
chip.sleepInterruptSetup(); // setup sleep function on the ATmega328p. Power-down mode is used here
// loop ****************************************************************
digitalWrite(POWER, LOW);
delay(1); // give some delay for SD card power to be low before processor sleeps to avoid it being stuck
chip.turnOffADC(); // turn off ADC to save power
chip.turnOffSPI(); // turn off SPI bus to save power
//chip.turnOffWDT(); // turn off WatchDog Timer to save power (does not work for Pro Mini - only works for Uno)
chip.turnOffBOD(); // turn off Brown-out detection to save power
chip.goodNight(); // put processor in extreme power down mode - GOODNIGHT!
// this function saves previous states of analog pins and sets them to LOW INPUTS
// average current draw on Mini Pro should now be around 0.195 mA (with both onboard LEDs taken out)
// Processor will only wake up with an interrupt generated from the RTC, which occurs every logging interval
chip.turnOnADC(); // enable ADC after processor wakes up
chip.turnOnSPI(); // turn on SPI bus once the processor wakes up
delay(1); // important delay to ensure SPI bus is properly activated
//RTC.checkDST(); // check and account for Daylight Saving Time in US
CO2ppm = GetCO2(0x68); // default address for K-30 CO2 sensor is 0x68
delay(50); // give some delay to ensure CO2 data is properly received from sensor
// account for dropped values
if(CO2ppm > 0)
_CO2ppm = CO2ppm;
if(CO2ppm <=0)
CO2ppm = _CO2ppm;
if(!sd.begin(SDcsPin, SPI_FULL_SPEED)) // very important - reinitialize SD card on the SPI bus
//if('A'=='B')
delay(10);
SDcardError();
delay(10);
file.open(filename, O_WRITE | O_AT_END); // open file in write mode
delay(1);
SPCR = 0; // reset SPI control register
file.print(time);
file.print(",");
file.print(CO2ppm); // print temperature upto 3 decimal places
file.println();
delay(10);
RTC.setNextAlarm(); //set next alarm before sleeping
delay(1);
// Get CO2 concentration ****************************************************************
int GetCO2(int address)
byte recieved[4] = {0,0,0,0}; // create an array to store bytes received from sensor
Wire.beginTransmission(address);
Wire.write(0x22);
Wire.write(0x00);
Wire.write(0x08);
Wire.write(0x2A);
Wire.endTransmission();
delay(20); // give delay to ensure transmission is complete
Wire.requestFrom(address,4);
delay(10);
byte i=0;
while(Wire.available())
recieved = Wire.read();
i++;*
byte checkSum = recieved[0] + recieved[1] + recieved[2];*
CO2ppm = (recieved[1] << 8) + recieved[2];*
if(checkSum == recieved[3])*
return CO2ppm;*
else*
return -1;*
// file timestamps ****************************************************************
void PrintFileTimeStamp() // Print timestamps to data file. Format: year, month, day, hour, min, sec
file.timestamp(T_WRITE, RTC.year, RTC.month, RTC.day, RTC.hour, RTC.minute, RTC.second); // edit date modified*
file.timestamp(T_ACCESS, RTC.year, RTC.month, RTC.day, RTC.hour, RTC.minute, RTC.second); // edit date accessed*
// SD card Error response ****************************************************************
void SDcardError()
Serial.print("SD Card Error");*
for(int i=0;i<3;i++) // blink LED 3 times to indicate SD card write error*
digitalWrite(LED, HIGH);*
delay(50);*
digitalWrite(LED, LOW);*
delay(150);*
