hello i am new to arduino i have to submit a rain intensity data logger in a next few hours
anybody please help me
i used the code
#include <SD.h>
const int rainPin = 2; // Digital pin for rain sensor
const int chipSelect = 10; // Chip select pin for SD card module
unsigned long rainDuration = 0; // Duration of rain in milliseconds
float rainIntensity = 0; // Rain intensity in mm/hour
File dataFile;
// Initialize SD card
if (SD.begin(chipSelect)) {
Serial.println("SD card initialized.");
Serial.println("SD card initialization failed.");
return;
// Open a file for writing data
dataFile = SD.open("rain_data.txt", FILE_WRITE);
if (dataFile) {
Serial.println("File opened successfully.");
dataFile.println("Rain Intensity (mm/hour) | Rain Duration (seconds)");
Serial.println("Error opening file.");
// Read the digital value from the rain sensor
int sensorValue = digitalRead(rainPin);
// Check if it's raining
if (sensorValue == HIGH) {
// Rain detected, calculate and log data
rainIntensity = 5.0; // Set a constant value for rain intensity (you may adjust based on your sensor)
rainDuration += millis();
// Print and log the rain intensity and duration
Serial.print("Rain Intensity: ");
Serial.print(rainIntensity);
Serial.print(" mm/hour | Rain Duration: ");
Serial.print(rainDuration / 1000); // Convert milliseconds to seconds
Serial.println(" seconds");
// Log data to SD card
if (dataFile) {
dataFile.print(rainIntensity);
dataFile.print(" | ");
dataFile.println(rainDuration / 1000); // Convert milliseconds to seconds
Serial.println("Error writing to file.");
delay(1000); // Delay for 1 second (adjust as needed)
this code gives rain intensity and at the next line it prints "error writing to file"
my connections are perfect
i use a 16 gb sd card from san disk
anybody please reply me immediately
