Data Logging Rate
I'm currently using an Uno to log accelerometer data to an SD. When I remove all the delays and allowed the program to run for a minute, it was saving data 5.5 times per second. Is there a way to increase this speed? Will removing the serial.prints impact the rate?
Thanks for your help.
Michael_Link:
One would think that the serial prints would have some impact, how much will require you to test ... a recompile is not that big of an inconvenience is it? But, the speed of SD is based on many, many factors: start reading here.
Post your code and a link to the accelerometer. Change from I2C to SPI is one way to speed things up. Removing Serial.print's also helps tremendously.
This project sampled & stored to SD card at 16 bit resolution - the ADC used supported that. What does your accelerometer support?
