I am trying to use the FRAM MB85RS64V break out on the Seeduino Xiao nRF52840 Sense.
However, the device doesn't seem to be detecting the FRAM at all.
It works well on the UNO.
I don't know what is wrong with the setup or code.
Can anyone guide me through this one?
#include <SPI.h>
#include "Adafruit_FRAM_SPI.h"
/* Example code for the Adafruit SPI FRAM breakout */
uint8_t FRAM_CS = 7;
//Adafruit_FRAM_SPI fram = Adafruit_FRAM_SPI(FRAM_CS); // use hardware SPI
uint8_t FRAM_SCK= 8;
uint8_t FRAM_MISO = 9;
uint8_t FRAM_MOSI = 10;
//Or use software SPI, any pins!
Adafruit_FRAM_SPI fram = Adafruit_FRAM_SPI(FRAM_SCK, FRAM_MISO, FRAM_MOSI, FRAM_CS);
uint16_t addr = 0;
void setup(void) {
while (!Serial) delay(10); // will pause Zero, Leonardo, etc until serial console opens
if (fram.begin()) {
Serial.println("Found SPI FRAM");
Serial.println("No SPI FRAM found ... check your connections\r\n");
while (1);
// Read the first byte
uint8_t test = fram.read8(0x0);
Serial.print("Restarted "); Serial.print(test); Serial.println(" times");
// Test write ++
fram.writeEnable(true);
fram.write8(0x0, test+1);
fram.writeEnable(false);
fram.write(0x1, (uint8_t *)"FTW!", 5);
// dump the entire 8K of memory!
uint8_t value;
for (uint16_t a = 0; a < 8192; a++) {
value = fram.read8(a);
if ((a % 32) == 0) {
Serial.print("\n 0x"); Serial.print(a, HEX); Serial.print(": ");
Serial.print("0x");
if (value < 0x1)
Serial.print('0');
Serial.print(value, HEX); Serial.print(" ");
void loop(void) {
