Data not reaching MySQL
Good Afternoon,
I hope that someone can please help.
My Code below should send data to MySQL. But for some reason... it just doesnt.
So if i copy and paste the url created (postStr) manually into the web browser, it submits the data to the DB perfectly, but it does not do it when running normally.
In my monitor, it shows connected and the link displays correctly as well...
Please assist? Where am I missing it?
#include <ESP8266WiFi.h>
#include <SimpleDHT.h>
const char* ssid = "MySSID";
const char* password = "MyPass";
const int httpPort = 80;
const char* server = "154.xxx.xxx.xxx";
const char* host = "154.xxx.xxx.xxx";
int i = 0;
int pinDHT11 = 2;
SimpleDHT11 dht11;
    WiFi.begin(ssid,password);
    while (WiFi.status() != WL_CONNECTED)
      delay (500);
      Serial.print(".");
  WiFiClient client;
  if (!client.connect(server,httpPort))
    Serial.println("Connection Failed");
    return;
    Serial.println("Connection Success");
  byte temperature = 0;
  byte humidity = 0;
  if (dht11.read(pinDHT11, &temperature, &humidity, NULL)) {
    Serial.print("Read DHT11 failed.");
    return;
if (client.connect(server,80)) {
    String postStr = "154.xxx.xxx.xxx/Node_set.php?";
            postStr +="&Temp=";
            postStr += String(temperature);
            postStr +="&Hum=";
            postStr += String(humidity);
  client.print(String("GET ") + postStr + " HTTP/1.1\r\n" +
    "Host: " + host + "r\n" +
    "Connection: close\r\n\r\n");
    Serial.print(postStr);
    Serial.print("\n\r");
    Serial.print("Temperature: ");
    Serial.print((int)temperature);
    Serial.print(" C\n\r");
    Serial.print("Humidity: ");
    Serial.print((int)humidity);
    Serial.print(" %\n\r");
  } // CLOSE IF CONNECT
  client.stop();
  Serial.println("Waiting…");
    delay (60000);
    i++;
Thank you very much!
Kind Regards
            postStr +="&Temp=";
            postStr +="&Hum=";
It is silly to all the get request string postStr.
The client is already connected to the server. The php script is not at /154.xxx.xxx.xxx on the server, is it?
The script is far more likely at / on the server.
It is time, now, for you to ditch the String class. sprintf() and a char array will do everything you need to.
Thank you very much for the reply!
Could you possibly give me an example of what you mean?
Then I can translate it into my code.
