I am using an Uno r3 with the Spark Fun Canbus Shield https://www.sparkfun.com/products/10039.
The card is a uSD (1gb pny) formatted FAT using the SD group’s tool.
The text file gets created but it is empty.
The shield uses SPI to interface with a CAN controller. I am beginning to think that the SPI commands to the can controller may be causing problems.
Here is some of my code:
#include <SPI.h>
#include <CANBusMod.h>
#include <SD.h>
// Define pins on mcp2515
#define CANSELECT 10
#define CANINT_D 2
// Define Joystick connection
#define UP A1
#define RIGHT A2
#define DOWN A3
#define CLICK A4
#define LEFT A5
#define SD_CS 9
File dataFile; // File for logging data
pinMode (SCK,OUTPUT);
pinMode (MISO,INPUT);
pinMode (MOSI, OUTPUT);
pinMode (CANSELECT, OUTPUT);
pinMode (CANINT_D, INPUT);
pinMode (SD_CS, OUTPUT);
// Pin mode for joystick
pinMode(UP,INPUT);
pinMode(DOWN,INPUT);
pinMode(LEFT,INPUT);
pinMode(RIGHT,INPUT);
pinMode(CLICK,INPUT);
// Enable internal pull-ups for joystick
digitalWrite(UP, HIGH);
digitalWrite(DOWN, HIGH);
digitalWrite(LEFT, HIGH);
digitalWrite(RIGHT, HIGH);
digitalWrite(CLICK, HIGH);
Serial.begin(9600); //connection with serial monitor
if(!SD.begin(SD_CS)) {
Serial.println("SD initialization failed.");
//return;
else {Serial.println("SD initialization successful.");}
delay(50);
dataFile = SD.open("DATALOG.TXT", FILE_WRITE);
if(dataFile){
dataFile.println("**********Log Start**********");
Serial.println("Logging...");
byte ret;
Serial.println("Beginning SPI Loopback testing...");
SPI.begin();
SPI.setDataMode(SPI_MODE0);
SPI.setClockDivider(SPI_CLOCK_DIV2);
SPI.setBitOrder(MSBFIRST);
// Code specific to setting up the CAN controller
// That I am omitting to save some space
// More omitted code specific to the CAN controller
if(digitalRead(CANINT_D) == 0) {// Check for interrupt from mcp2515
//Serial.println("Interrupt!");
readBus();
// Check for joystick click to close log file
if (digitalRead(CLICK) == 0){
if(dataFile){
dataFile.println("***********Log End***********");
dataFile.close();
Serial.println("Done");
void readBus() {
byte rx_status, len, i;
unsigned short id_h, id_l, id_full;
byte data[8];
// Omitted code specific to receiving data from the CAN controller
// and formatting it for output to the serial monitor and text file
Serial.print(id_h);
Serial.print(", ");
Serial.print(id_l);
Serial.print(", ");
Serial.print(id_full);
Serial.print(", ");
Serial.print(len);
for(i = 0;i<len;i++){
Serial.print(", ");
Serial.print(data[i]);
// Print to data log file
if(dataFile){
dataFile.print(id_h);
dataFile.print(", ");
dataFile.print(id_l);
dataFile.print(id_full);
dataFile.print(len);
dataFile.print(data[i]);
dataFile.println();
else{
Serial.println("Unable to access file");
The serial monitor is displaying this: (The program is just sending the same data packet over and over)
Any help you guys can provide would be much appreciated!
