The dust sensor worked on the Arduino. The Arduino can fetch datas (raw signal values) like the above link posted, which ranges from 200~350 in an office room. I can simply insert a pen in the hole of dust sensor to make the dust density more condense. Datas change from 350.00 to 764.00 while inserting a pen.
But if I mounted the Arduino with an Ethernet shield. The Arduino got so many zero datas returned from the sensor and some other values were kind of weird (the raw signal value randomly got 18, 47, 35..).
I'm utilizing a Sharp dust sensor GP2Y1010AU0F along with an Arduino Uno in a project. Is there any official example or test code that I can upload or reference to test my sensor? Any help would be appreciated!
KayEv290:
Most probably power supply noise - ethernet shield takes a lot of power and unless the 5V rail
is good and stiff this might allow ethernet board to inject noise via the sensor's power rail. Add more
decoupling on the sensor power rail (not the LED power, that's not the issue I think).
Measure your 5V rail and check its not drooping at all. Best to avoid powering via USB for
this kind of use, USB power is shockingly bad for analog use. 7V or so into Vin/power jack
allows the on-board linear regulator to generate a clean 5V
