This is a piece of code in python which sends the data. So, I have to send it like a string, but my data are integers.
Here is my problem. I really don't get it, how to process data in arduino. I get the data from serial.read function (HC-06 uses serial communication), but then I have numbers in string.
How can I convert this numbers in string to integers?
Thank you very much in advance.
I suspect one of the examples in serial input basics will be suitable. There is also a parse example.
It is not essential to send data as strings but if you send "raw" integers you need to take account of endian-ness. And using strings makes debugging easier so I would use them unless performance is a big issue.
