Data persistence in oled menu
Ey, I have an ARDUINO UNO with an OLED Display I2C SH1106 (128*32). I coded a OLED MENU with only one pressbutton (using oneButton Library for that)
The code is for AUTOMATIC CONTROL PLANT.
When i press "INICIAR CICLO" i verify if TYPE, FASE, and COOLER has a value different to the initial value 'N/A'. IF Yes, start a CONTROL method. If NOT,
only show an error screen.
The first time runs ok, and show ok the info page. But after x time, i refresh the info page and i lost ONLY TO SHOW the selected data (But it still runs the CONTROL method)
I need to use the selected data always till someone change it, but if change only TYPE (or one of the values), i need to reuse the first selected values for FASE and COOLER.
attached the code
#include <DHT.h>
#include <DHT_U.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH1106.h>
#include <OneButton.h>
#define RELE_ONE 2
#define RELE_TWO 3
#define RELE_THREE 4
#define humidity_sensor A0
#define temperature_sensor 5
OneButton button(A1, true);
DHT dht(temperature_sensor, DHT22);
Adafruit_SH1106 display(-1);
int pic = 0;
String FASE = "N/A";
String TYPE = "N/A";
String COOLER = "N/A";
boolean start = false;
boolean reload = true;
long lastmillis = 0;
long maxtime = 5000;
int event = 0;
const int light_control_auto = 6000, light_control_reg = 8000, temperature_control_growing = 2000, temperature_control_flowering = 4000, MAX_TEMP = 22, MIN_HUM = 500, humidity_control_growing = 5000, humidity_control_flowering = 7000;
int temperature_control, humidity_control, light_control;
int temperature_measure_sensor, humidity_measure_sensor;
  dht.begin();
  display.begin(SH1106_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
  display.clearDisplay();
  button.attachDoubleClick(doubleclick);
  button.attachClick(singleClick);
  button.attachLongPressStart(longPressStart);
  button.attachLongPressStop(longPressStop);
  pinMode(humidity_sensor, INPUT);
  pinMode(RELE_ONE, OUTPUT);
  pinMode(RELE_TWO, OUTPUT);
  pinMode(RELE_THREE, OUTPUT);
  digitalWrite(RELE_ONE, HIGH);
  digitalWrite(RELE_TWO, HIGH);
  digitalWrite(RELE_THREE, HIGH);
  button.tick();
  if (reload) {
    menu();
  if (millis() >= (lastmillis + maxtime))
    pic = 0;
  if (start) {
    control();
void control() {
  unsigned long TIME = millis();
  int light_event = 0;
  int humidity_event = 0;
  int temperature_measure_sensor = dht.readTemperature();
  int humidity_measure_sensor = analogRead(humidity_sensor);
  int temperature_event = 0;
  boolean isCooling = false;
  boolean isIrrigation = false;
  //control de humedad
  if (TIME - humidity_event >= humidity_control || isIrrigation) {
    humidity_event = TIME;
    if (humidity_measure_sensor > MIN_HUM) {
      digitalWrite(RELE_TWO, LOW);
      isIrrigation = true;
  // control de los ventiladores
  if (temperature_control != 0 && (TIME - temperature_event >= temperature_control || isCooling)) {
    temperature_event = TIME;
    if (temperature_measure_sensor > MAX_TEMP) {
      digitalWrite(RELE_ONE, LOW);
      isCooling = true;
      isCooling = false;
  //control de luces
  if (TIME - light_event >= light_control) {
    light_event = TIME;
    digitalWrite(RELE_THREE, LOW);
void singleClick() {
  const int maxPics_L1 = 4;
  const int maxPics_L2 = 2;
  lastmillis = millis();
  if (pic >= 0 && pic < 10) {
    pic >= maxPics_L1 ? pic = 1 : pic++;
  if (pic >= 10 && pic < 20) {
    pic > maxPics_L2 + 10 ? pic = 11 : pic++;
  if (pic >= 20 && pic < 30) {
    pic > maxPics_L2 * 10 + maxPics_L2 ? pic = 21 : pic++;
  if (pic >= 30 && pic < 40) {
    pic >= maxPics_L2 * 10 + 10 + maxPics_L2 ? pic = 31 : pic++;
  reload = true;
void doubleclick() {
  switch (pic) {
    case 11:
      TYPE = "REGULAR";
      pic = 1;
    case 12:
      TYPE = "AUTO";
      pic = 1;
    case 21:
      FASE = "CRECIMIENTO";
      pic = 2;
    case 22:
      FASE = "FLORACION";
      pic = 2;
    case 31:
      COOLER = "SI";
      pic = 3;
    case 32:
      COOLER = "NO";
      pic = 3;
    case 4:
      start = false;
      verify();
void verify () {
  if (TYPE != "N/A" && FASE != "N/A" && COOLER != "N/A") {
    start = true;
    temperature_control = COOLER == "SI" ? FASE == "CRECIMIENTO" ? temperature_control_growing : temperature_control_flowering : 0;
    humidity_control = FASE == "CRECIMIENTO" ? humidity_control_growing : humidity_control_flowering;
    light_control = TYPE == "REGULAR" ?  light_control_reg : light_control_auto;
    pic = 0;
  else {
    pic = 6;
void longPressStart() {
  if (pic == 1)
    pic = pic + 10;
  } else if (pic == 2 || pic == 3) {
    pic = pic * 10 + 1;
  } else if (pic == 4) {
    pic = 0;
void longPressStop() {
void menu()
  if (pic == 0)
    reload = false;
    header();
    body();
    refresh();
  // TIPO
  if (pic == 1)
    header();
    display.setCursor(0, 11);  display.print (F("> TIPO"));
    display.setCursor(0, 20);  display.print (F(" ETAPA"));
    display.setCursor(0, 30);  display.print (F(" COOLERS"));
    display.setCursor(0, 50);  display.print (F(" INICIAR CICLO"));
    refresh();
  // ETAPA
  if (pic == 2)
    header();
    display.setCursor(0, 11);  display.print (F(" TIPO"));
    display.setCursor(0, 20);  display.print (F("> ETAPA"));
    refresh();
  // VENTILADOR
  if (pic == 3)
    header();
    display.setCursor(0, 30);  display.print (F("> COOLERS"));
    refresh();
  //INFO
  if (pic == 4)
    header();
    display.setCursor(0, 50);  display.print (F("> INICIAR CICLO"));
    refresh();
  if (pic == 5)
    header();
    irrigationStart();
    refresh();
  if (pic == 6)
    header();
    fail();
    refresh();
  if (pic == 11)
    header();
    display.setCursor(0, 11);  display.print (F("TIPO"));
    display.setCursor(0, 20);  display.print (F("> REGULAR"));
    display.setCursor(0, 30);  display.print (F("AUTO"));
    refresh();
  if (pic == 12)
    header();
    display.setCursor(0, 20);  display.print (F("REGULAR"));
    display.setCursor(0, 30);  display.print (F("> AUTO"));
    refresh();
  if (pic == 21)
    header();
    display.setCursor(0, 11);  display.print (F("ETAPA"));
    display.setCursor(0, 20);  display.print (F("> CRECIMIENTO"));
    display.setCursor(0, 30);  display.print (F("FLORACION"));
    refresh();
  if (pic == 22)
    header();
    display.setCursor(0, 20);  display.print (F("CRECIMIENTO"));
    display.setCursor(0, 30);  display.print (F("> FLORACION"));
    refresh();
  if (pic == 31)
    header();
    display.setCursor(0, 11);  display.print (F("COOLERS"));
    display.setCursor(0, 20);  display.print (F("> SI"));
    display.setCursor(0, 30);  display.print (F("NO"));
    refresh();
  if (pic == 32)
    header();
    display.setCursor(0, 20);  display.print (F("SI"));
    display.setCursor(0, 30);  display.print (F("> NO"));
    refresh();
void header()
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(22, 0);  display.print(F("SAR v0.1"));
  display.drawLine (0, 9, 128, 9, WHITE);
void body()
//  temperature_measure_sensor = dht.readTemperature();
//  humidity_measure_sensor = analogRead(humidity_sensor);
//  int humidity = map(humidity_measure_sensor , 1023, 0, 0, 100);
  display.print (F("TIPO: "));
  display.println(TYPE);
  display.print (F("ETAPA: "));
  display.println(FASE);
  display.print (F("COOLERS: "));
  display.println(COOLER);
//  display.print (F("TEMPERATURA: "));
//  display.println(temperature_measure_sensor);
//  display.print (F("HUMEDAD TIERRA: "));
//  display.print(humidity);
//  display.println('%');
void irrigationStart()
  display.setTextSize(2);
  display.print (F("CICLO INICIADO"));
void fail()
  display.print (F("REVISE PARAMENTROS"));
void refresh()
  display.display();
  delay(00);
Assuming "x" is more or less random, crashes or malfunctions are often due to the use of String objects. They fragment memory, which is an especially serious problem on AVR-based Arduinos like the Uno.
Strings are never necessary, so get rid of all String objects and operations, and the problem will probably go away.
See Extracting hour/minute/second/date from String - #8 by dev_1
I am not convinced that String is the problem here.
There is very little (if any) string handling going on.
@fetichex By the way: compliments for sending comprehensible code in code tags with a good explanation of the issue!
Did you try to follow where the program goes?
Is reload equal to true at the moment you expect the info to be shown?
Serial.print(reload); should give you an answer to that...
I do not really like the coding style with nested ?: operators in one line. I would need to dive into the C manual to lookup precedence of operators. Also the line is very long. Therefore overview is lost.
