I have my eye and eyelid code working properly. Now, I'm looking to smooth things out a bit. The input , and output, values causing jitters in my servos. I was looking at data smoothing, and the examples I've looked at deal with the input side. Can this be used on the outputs? Or both? Since I'm modifying values based on other values, what do you feel would give the most benefit?
Smoothing example.
const int numReadings = 10;
int readings[numReadings]; // the readings from the analog input
int readIndex = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
int inputPin = A0;
// initialize serial communication with computer:
// initialize all the readings to 0:
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
// subtract the last reading:
total = total - readings[readIndex];
// read from the sensor:
readings[readIndex] = analogRead(inputPin);
// add the reading to the total:
total = total + readings[readIndex];
// advance to the next position in the array:
readIndex = readIndex + 1;
// if we're at the end of the array...
if (readIndex >= numReadings) {
// ...wrap around to the beginning:
readIndex = 0;
// calculate the average:
average = total / numReadings;
// send it to the computer as ASCII digits
Serial.println(average);
delay(1); // delay in between reads for stability
My code.
#include <Servo.h>
// create servo object to control a servo
Servo servo1; // upper left eyelid
Servo servo2; // lower left eyelid
Servo servo3; // upper right eyelid
Servo servo4; // lower right eyelid
Servo servo5; // left eye horizontal
Servo servo6; // right eye horizontal
Servo servo7; // left eye vertical
Servo servo8; // right eye vertical
int pospot1 = A0;
int lrpos = A1;
int udpos = A2;
int blinksw = 52;
int lidpos;
int lidposlu;
int lidposll;
int lidposru;
int lidposrl;
int lefteyeud;
int lefteyelr;
int righteyeud;
int righteyelr;
pinMode(A0,INPUT);
pinMode(A1,INPUT);
pinMode(A2,INPUT);
pinMode(52,INPUT);
servo1.attach(9); // attaches the servos to the servo object
servo2.attach(8);
servo3.attach(7);
servo4.attach(6);
servo5.attach(5);
servo6.attach(4);
servo7.attach(3);
servo8.attach(2);
Serial.begin(38400);
lidpos = analogRead(pospot1);
lidpos = map(lidpos, 0, 1023, 1370, 1800);
//left eye code
lefteyelr = map(analogRead(lrpos), 0, 1023, 580, 2370);
lefteyeud = map(analogRead(udpos), 0, 1023, 550, 2400);
//right eye code
righteyelr = map(analogRead(lrpos), 0, 1023, 580, 2370);
righteyeud = map(analogRead(udpos), 0, 1023, 550, 2400);
// eye position write
servo5.writeMicroseconds(lefteyelr);
servo6.writeMicroseconds(lefteyeud);
servo7.writeMicroseconds(righteyelr);
servo8.writeMicroseconds(righteyeud);
// eye lid position and blink function
lidpos = map(analogRead(pospot1), 0, 1023, 1370, 1800);
int eyeVerticalPosition = map(analogRead(udpos), 0, 1023, 550, 2400);
int lidposlu = constrain(lidpos + ((lefteyeud-1500)/5), 1370, 1800);
int lidposll = constrain(lidpos - ((lefteyeud-1500)/5), 1370, 1800);
int lidposru = constrain(lidpos + ((righteyeud-1500)/5), 1370, 1800);
int lidposrl = constrain(lidpos - ((righteyeud-1500)/5), 1370, 1800);
if (digitalRead(blinksw) == HIGH)
servo1.writeMicroseconds(1800); // tell servos to blink
servo2.writeMicroseconds(1800);
servo3.writeMicroseconds(1800);
servo4.writeMicroseconds(1800);
Serial.println("Blink");
delay(400);
else (digitalRead(blinksw) == LOW);
servo1.writeMicroseconds(lidposlu); // set eyelid position
servo2.writeMicroseconds(lidposll);
servo3.writeMicroseconds(lidposru);
servo4.writeMicroseconds(lidposrl);
delay(25);
// debug serial info
Serial.print(lidpos);
Serial.print(',');
Serial.print(lefteyelr);
Serial.print(',');
Serial.print(lefteyeud);
Serial.print(',');
Serial.print(righteyelr);
Serial.print(',');
Serial.println(righteyeud);
delay(20);
