Data Storage
In Arduino C++ do variables lose their stored data at the completion of a sub or function? (little vb6 lingo there) The reason why I ask is because the string is appended and there's no easy way to clear the string at the completion of what is called a Sub or Function in Visual Basic 6.0. In vb6 the variables lose stored data unless they are declared as static.
double getdivisions()
char key = kpd.getKey();
double Degrees = 0;
string divstr;
int divs = 0;
lcd.clear();
lcd.setCursor(0,1);
lcd.print("Enter Division:");
lcd.setCursor(0,3);
lcd.print("OK = # ");
lcd.print((char)60);
lcd.print((char)45);
lcd.print(" D");
lcd.setCursor(16,1);
while(key != '#')
switch (key)
case NO_KEY: break;
case 'D': lcd.setCursor(16,1);
lcd.print(" ");
divstr.clear()
case '0': divstr += ("0");
case '1': divstr += ("1");
case '2': divstr += ("2");
case '3': divstr += ("3");
case '4': divstr += ("4");
case '5': divstr += ("5");
case '6': divstr += ("6");
case '7': divstr += ("7");
case '8': divstr += ("8");
case '9': divstr += ("9");
lcd.print(key);
key = kpd.getKey();
Degrees = (360/divstr toInt());
return Degrees;
Please learn some C/C++ lingo: it is a function.
It is not "Arduino C++". gcc is used as a compiler and it is a real compiler for C and C++. Arduino adds some libraries and functions to make common issues easier.
The answer to your question is "It depends." C++ allows you to define variables in various places (e.g. globally or local to the function) and with various modifiers (e.g. static) that affect how the variable is handled.
A C string (the lower case 's' is important) is typically an array of char. Putting a zero (or null or other things) into the zeroth position would clear the string if necessary.
"Arduino C++" has the same variable scope and lifetime rules as "real" C++ because it is real C++.
In your example
1)
Degrees will be returned and after that no longer exist.
2)
divstr will be empty when the function is called; it's a new variable. The declaration should be
String divstr;
Note the capital S.
Side notes:
1)
If the character enter is e.g. 4, divstr will contain 456789. This is due to the missing break statements for the cases 0..9.
2)
Stay away from the String class (capital S); it can result in memory fragmentation and as a result of that unexpected behaviour at run time. Learn to use so-called c-strings (NUL terminated character arrays).
3)
Please learn to indent your code properly (use tools -> autoformat in the IDE); it helps you (and us) in following the flow of a program.
