jaddion82052:
// Sample rate 20.0 Hz
#include <Wire.h>
#include <SD.h>
#define BMP085_ADDRESS 0x77 // I2C address of BMP085
const unsigned char OSS = 0; // Oversampling Setting
// Calibration values
int ac1;
int ac2;
int ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1;
int b2;
int mb;
int mc;
int md;
int buttonpin = 7;
int CS_pin = 10;
int led_pin = 5;
int id = 0;
float x=0;
float k=0.4;
float a = 0;
int active = 0;
float starttime, endtime, timetaken, samplerate, time1, time2;
float startheight;
float samples = 300;
// b5 is calculated in bmp085GetTemperature(...), this variable is also used in bmp085GetPressure(...)
// so ...Temperature(...) must be called before ...Pressure(...).
long b5;
short temperature;
long pressure;
// Use these for altitude conversions
const float p0 = 101325; // Pressure at sea level (Pa)
float altitude;
Wire.begin();
bmp085Calibration();
Serial.println("Initializing card");
pinMode(CS_pin, OUTPUT);
pinMode(led_pin, OUTPUT);
pinMode(buttonpin, INPUT);
if(!SD.begin(CS_pin))
Serial.println("Card Failed");
return;
Serial.println("Card Setup Ready");
File logFile = SD.open("TEST18.csv", FILE_WRITE);
if(logFile)
String header = "ID, Time (s), Altitude (m), X (m)";
logFile.println(header);
logFile.close();
int buttonstate = digitalRead(buttonpin);
if (buttonstate == 1 && active == 0 && id < samples)
active = 1;
digitalWrite(led_pin, HIGH);
starttime = millis();
if (id==samples && active==1)
endtime = millis();
timetaken = endtime - starttime;
samplerate = samples/(timetaken/1000);
Serial.println(samplerate);
digitalWrite(led_pin, LOW);
active = 0;
id = id + 1;
if(id<samples && active==1)
if(logFile)
String dataString = String(id) + ", ";
float time = (millis() - starttime)/1000;
pressure = bmp085GetPressure(bmp085ReadUP());
altitude = (float)44330 * (1 - pow(((float) pressure/p0), 0.190295));
if (id==0 && active==1)
startheight = altitude;
float a = altitude - startheight;
x=x+k*(a-x);
logFile.print(dataString); // Can a string be created before and only 1 write operation carried out?
logFile.print(time);
logFile.print(", ");
logFile.print(a);
logFile.println(x);
logFile.close();
//Serial.println(x);
id++;
// Stores all of the bmp085's calibration values into global variables
// Calibration values are required to calculate temp and pressure
// This function should be called at the beginning of the program
void bmp085Calibration()
ac1 = bmp085ReadInt(0xAA);
ac2 = bmp085ReadInt(0xAC);
ac3 = bmp085ReadInt(0xAE);
ac4 = bmp085ReadInt(0xB0);
ac5 = bmp085ReadInt(0xB2);
ac6 = bmp085ReadInt(0xB4);
b1 = bmp085ReadInt(0xB6);
b2 = bmp085ReadInt(0xB8);
mb = bmp085ReadInt(0xBA);
mc = bmp085ReadInt(0xBC);
md = bmp085ReadInt(0xBE);
// Calculate temperature given ut.
// Value returned will be in units of 0.1 deg C
short bmp085GetTemperature(unsigned int ut)
long x1, x2;
x1 = (((long)ut - (long)ac6)*(long)ac5) >> 15;
x2 = ((long)mc << 11)/(x1 + md);
b5 = x1 + x2;
return ((b5 + 8)>>4);
// Calculate pressure given up
// calibration values must be known
// b5 is also required so bmp085GetTemperature(...) must be called first.
// Value returned will be pressure in units of Pa.
long bmp085GetPressure(unsigned long up)
long x1, x2, x3, b3, b6, p;
unsigned long b4, b7;
b6 = b5 - 4000;
// Calculate B3
x1 = (b2 * (b6 * b6)>>12)>>11;
x2 = (ac2 * b6)>>11;
x3 = x1 + x2;
b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
// Calculate B4
x1 = (ac3 * b6)>>13;
x2 = (b1 * ((b6 * b6)>>12))>>16;
x3 = ((x1 + x2) + 2)>>2;
b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
b7 = ((unsigned long)(up - b3) * (50000>>OSS));
if (b7 < 0x80000000)
p = (b7<<1)/b4;
p = (b7/b4)<<1;
x1 = (p>>8) * (p>>8);
x1 = (x1 * 3038)>>16;
x2 = (-7357 * p)>>16;
p += (x1 + x2 + 3791)>>4;
return p;
// Read 1 byte from the BMP085 at 'address'
char bmp085Read(unsigned char address)
unsigned char data;
Wire.beginTransmission(BMP085_ADDRESS);
Wire.write(address);
Wire.endTransmission();
Wire.requestFrom(BMP085_ADDRESS, 1);
while(!Wire.available())
return Wire.read();
// Read 2 bytes from the BMP085
// First byte will be from 'address'
// Second byte will be from 'address'+1
int bmp085ReadInt(unsigned char address)
unsigned char msb, lsb;
Wire.requestFrom(BMP085_ADDRESS, 2);
while(Wire.available()<2)
msb = Wire.read();
lsb = Wire.read();
return (int) msb<<8 | lsb;
// Read the uncompensated temperature value
unsigned int bmp085ReadUT()
unsigned int ut;
// Write 0x2E into Register 0xF4
// This requests a temperature reading
Wire.write(0xF4);
Wire.write(0x2E);
// Wait at least 4.5ms
delay(5);
// Read two bytes from registers 0xF6 and 0xF7
ut = bmp085ReadInt(0xF6);
return ut;
// Read the uncompensated pressure value
unsigned long bmp085ReadUP()
unsigned char msb, lsb, xlsb;
unsigned long up = 0;
// Write 0x34+(OSS<<6) into register 0xF4
// Request a pressure reading w/ oversampling setting
Wire.write(0xF4);
Wire.write(0x34 + (OSS<<6));
// Wait for conversion, delay time dependent on OSS
delay(2 + (3<<OSS));
// Read register 0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
Wire.write(0xF6);
Wire.requestFrom(BMP085_ADDRESS, 3);
// Wait for data to become available
while(Wire.available() < 3)
msb = Wire.read();
lsb = Wire.read();
xlsb = Wire.read();
up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8-OSS);
return up;
There is all my code out of interest.
Ah ok, well thanks for the advice, I guess 20Hz will be the limit for this unless I move to a different data storage solution. (Which I don't really want to), thank you.
I wonder if the sensor readings aren't affecting that as well... if you write constants to the SD card, how fast can you write? I'm not experienced with that sensor, but I am with the BME280 and it is poky (humidity).
floating point math is slow, too. I wonder if too if you reduced some of that and just stored raw data.
You can try a few things to speed that along.
