Data to send PC to WiFi
Dear All
I need to send data from my PC to ESP 8266
Is there any PC software to installed
The data that I need to send is like 0x99
please advice
Not nearly enough information to answer. Try adding details. What code is on the esp? Where is the data coming from?
Dear Delta Thanks for the reply
the data coming from my laptop to ESP
The ESP already programmed and connected with my laptop
Now I need to send data from laptop to ESP
I need to software to send data from laptop
please advice
Ok but answer the questions I asked.
PA3040: Dear Delta Thanks for the reply / the data coming from my laptop to ESP / The ESP already programmed and connected with my laptop
Now I need to send data from laptop to ESP / I need to software to send data from laptop
please advice
So, an assumption: You programmed an ESP8266 with ArduinoIDE? That is, you are NOT using the "AT" commands?
Assuming the above, you have a USB-Serial adapter that allows you to connect the ESP8266? Or, are you using a NodeMCU board that already has the USB-serial?
See why more information is required?
Anyway ... if you have Serial-USB or are using a NodeMCU, you can move data back and forth over the USB-serial interface.
IF for some strange reason you are using the "AT" version of the firmware on the ESP8266, things are going to be very difficult.
Ray
Dear Ray Thanks for the reply
I am using ESP8266 12E ( not a Node MCU)
I am not in using AT command version
Currently my ESP programed as a web server I think, which I can connect with my laptop web browser and I can ON and OFF LED connected with ESP using my laptop web browser
My new requirement is
I need to ON and OFF the LED using software which installed on my Laptop not from web browser
please advice
Thanks in advance
There are so many factors to this question that a chapter from a book could be written. Rather than bias you with my way, read up a bit on the various ways that are available in This Google Search
When you pick the solution you wish to implement, then if you have issues, come back in a new thread and we will try to get you over any rough spots.
Ray
Dear ray Thank for the links and advice
I when through the links that you have been provided. All the links are discussing with LED controlling with WEB browser. and RS232 connected Rx Tx with WiFi module using USB. But my requirement is little different
My Requirement is
PC software -------> Connect to its WiFi module of PC -------> then PC send data using WiFi -----> Then my ESP receive data ------> ESP Rx Tx connected with Arduino Rx Tx ------> Then I can collect data from Arduino
Hoped you understand my question
please advice
Thanks in advance
PA3040: Dear ray Thank for the links and advice
My Requirement is
please advice
Thanks in advance
Yes... backward from what I read initially ... but, I understand, I think :o
Well, I think this is the root issue in your plan ...
which means the PC's WiFi adapter must change to support point-to-point. I'm going to be honest and tell you that I have never researched if the PC 802.11 module can be commandeered by user-written software .... I suspect this would be something like having Sniffer hook the network stack - but for sending instead of promiscuous receive.
Would this not make more sense:
GPS receives data -------- > Tx to Rx on ESP8266 serial ---------> ESP8266 sends data to any listening node Listening ESP8266 node -----> Receives data -----> Sketch on ESP8266 processes data & displays time/date
That is what my project here does.
If you replace the GPS in the above scenario to be the PC USB to serial and if you use the ESP8266 as an Arduino programmed module you essentially have your WiFi connection for $4 x 2 = $8 (NodeMCU from AliExpress.)
You can also program the ESP8266's in LUA to do point-to-point communication.
... and there are ESP8266 to ESP8266 (node-node) examples out on the ESP8266.com site which uses the ESP8266 somewhat like a WiFi bi-directional modem.
Ray
Hi PA3040, Have you got success in communication between ESP8266 and laptop over wifi. I have the same requirement. Please reply me if it is possible.
Hi PA3040, I have a similar requirement where Ii need to send data from my PC to my adafruit HUZZAH with ESP8266 and acknowledge the reception of data back to my PC. I'm new to networking and arduino, I hope you have sucessfully implemented. Could you please throw some light on how to get started with this ?
