Data Type error?
#ifndef _FT_DATATYPES_H_
#define _FT_DATATYPES_H_
#include <Arduino.h>
#define FT_FALSE           (0)
#define FT_TRUE            (1)
/* Inclusion of datatypes from MSVC */
#if defined(MSVC_PLATFORM) || defined(MSVC_FT800EMU)
typedef char ft_char8_t;
typedef signed char ft_schar8_t;
typedef unsigned char ft_uchar8_t;
typedef ft_uchar8_t ft_uint8_t;
typedef short  ft_int16_t;
typedef unsigned short ft_uint16_t;
typedef unsigned int ft_uint32_t;
typedef int ft_int32_t;
typedef void ft_void_t;
typedef long long ft_int64_t;
typedef unsigned long long ft_uint64_t;
typedef float ft_float_t;
typedef double ft_double_t;
typedef char ft_bool_t;
#define FT_BYTE_SIZE (1)
#define FT_SHORT_SIZE (2)
#define FT_WORD_SIZE (4)
#define FT_DWORD_SIZE (8)
#define FT_NUMBITS_IN_BYTE (1*8)
#define FT_NUMBITS_IN_SHORT (2*8)
#define FT_NUMBITS_IN_WORD (4*8)
#define FT_NUMBITS_IN_DWORD (8*8)
#define ft_prog_uchar8_t  ft_uchar8_t
#define ft_prog_char8_t   ft_char8_t
#define ft_prog_uint16_t  ft_uint16_t
#define ft_random(x)		(rand() % (x))
#define ft_millis()         GetTickCount()
#define ft_pgm_read_byte_near(x)   (*(x))
#define ft_pgm_read_byte(x)        (*(x))
#define ft_strcpy_P     strcpy
#define ft_strlen_P     strlen
#define ft_delay(x) Ft_Gpu_Hal_Sleep(x)
#define FT_DBGPRINT(x)  printf(x)
#define FT_PROGMEM
#define ft_pgm_read_word(addr)   (*(ft_int16_t*)(addr))
#endif
#ifdef ARDUINO_PLATFORM
typedef byte ft_uint8_t;
typedef int  ft_int16_t;
typedef word ft_uint16_t;
typedef unsigned long ft_uint32_t;
typedef long ft_int32_t;
typedef boolean ft_bool_t;
typedef prog_uchar  ft_prog_uchar8_t;
typedef prog_char   ft_prog_char8_t;
typedef prog_uint16_t ft_prog_uint16_t;
//#define ft_delay(x) delay(x)
#define FT_PROGMEM PROGMEM
#define ft_pgm_read_byte_near pgm_read_byte_near
#define ft_pgm_read_byte pgm_read_byte
#define ft_pgm_read_word pgm_read_word
#define ft_random(x)		(random(x))
#define TRUE     (1)
#endif
#endif /*_FT_DATATYPES_H_*/
/* Nothing beyond this*/
it is giving error please provide us kind support i am a beginner thank you best regards
It helps if you post the complete error output by the IDE. Copy and paste the error message(s) into this discussion.
Except for the full error, please provide a sketch that demonstrates the problem. setup() and loop() are missing in the code that you posted (they might be elsewhere in another file) but that can be one error.
Which board are you compiling for?
