hi i have a large datavision display dvf-20210-1
2x20 caracters it should be compatible with hd44780
i connected it but i have only black rectangles
has somebody experians with this display ?
thanks for answer
jean-marie
thanks for answer
jean-marie
Be sure you wired it correctly, if it is adjust the contrast pot! Let us know if that solved it. The link was a big help.
hi gilshultz
thanks for answer
first i followed the schematic on the link.
but no contrast.
then i found an info that these lcd's need a negative bias on pin 3 because they have a large temperature range.
i used a 9v battery. now i have contrast and 2x20 black boxes on the display
when you use the backlight you need 500mA at 4V
i used the standard arduino example to display " hello world"
but no luck no text
regards jean-marie
hi i found a solution
display works only in 8 bit mode and you need to feed a negative voltage to pin3
regards jean-marie
my sketch:
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int RS = 12, EN = 11, D0 = 10, D1 = 9, D2 = 8, D3 = 7 , D4 = 6, D5 = 5, D6 = 4, D7 = 3;
LiquidCrystal lcd(RS, EN, D0, D1, D2, D3, D4, D5, D6, D7); // 8-bit mode
// set up the LCD's number of columns and rows:
lcd.begin(20, 2);
// Print a message to the LCD.
lcd.print("ON7EN");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis() / 1000);
