Data won't write to SD within loop
I finally got my sensor to read when the linear actuator starts and keep going for a short time after, but I can't get the sensor data to store on the SD card? I verified it was taking the reading by writing serially.
I am using the same script from before I added the linear actuator, and it was writing to the SD fine. any ideas??
actuator.ino (3.3 KB)
Can't see your code.
Remember the code tags
Filenames need to adhere to the 8.3 format, your's doesn't.
OP's code (as is)
#include <Wire.h>
#include "AS726X.h"
#include <SPI.h>
#include <SD.h>
AS726X sensor;//Creates the sensor object
byte GAIN = 2;
byte MEASUREMENT_MODE = 0;
byte integrationValue = 200; // Change this between 1 - 255 for longer intergration times and more readings.
const int CHANNEL_0 = 0;
int buttonApin = 9;
const int chipSelect = 8;
float sensordataViolet;
float sensordataBlue;
float sensordataGreen;
float sensordataYellow;
float sensordataOrange;
float sensordataRed;
//unsigned long previousTime1;
const int forwards = 7;
const int backwards = 6;//assign relay INx pin to arduino pin
//int  j = 0;
pinMode(buttonApin, INPUT_PULLUP);
pinMode(10, OUTPUT);
   // The chipSelect pin you use should also be set to output
   Serial.println("Initializing SD card");
pinMode(chipSelect, OUTPUT);
  // see if the card is present and can be initialized:
   if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
     //don't do anything more:
    return;
  Serial.println("card initialized.");
//SD.begin(chipSelect);
Wire.begin();
pinMode(forwards, OUTPUT);//set relay as an output
pinMode(backwards, OUTPUT);//set relay as an output
sensor.begin();
    int  j = 0;
   if (digitalRead(buttonApin) == LOW) // low means on/ pushed. it is when pushed it connects the wire
 digitalWrite(forwards, LOW);
 digitalWrite(backwards, HIGH);//Activate the relay  to go out. Note they must be different to move the motor
do {
    sensor.enableBulb();
    sensor.takeMeasurements();
    sensordataViolet = sensor.getCalibratedViolet();
    sensordataBlue = sensor.getCalibratedBlue();
    sensordataGreen = sensor.getCalibratedGreen();
    sensordataYellow = sensor.getCalibratedYellow();
    sensordataOrange = sensor.getCalibratedOrange();
    sensordataRed = sensor.getCalibratedRed();
 File dataFile = SD.open("lactuator.csv", FILE_WRITE);
    dataFile.println(" 00000, 450 , 500 , 550 , 570 , 600 , 650 "); // blank line
    //String header = "V, B, G, O, Y, R"; // headers
    //dataFile.print(previousTime1);
      dataFile.print(",");
    dataFile.print(sensordataViolet);
    dataFile.print(sensordataBlue);
    dataFile.print(sensordataGreen);
    dataFile.print(sensordataYellow);
    dataFile.print(sensordataOrange);
    dataFile.print(sensordataRed);
    dataFile.flush();
    dataFile.close();
    Serial.println(sensordataViolet);
    Serial.println(sensordataBlue);
    Serial.println(sensordataGreen);
    Serial.println(sensordataYellow);
    Serial.println(sensordataOrange);
    Serial.println(sensordataRed);
   //sensor.disableBulb();
    j = j+1;
} while ( j < 10  ); // hopefully this runs throug
 delay(2000); // wait 2 seconds
   //dataFile.close();
// I might need this in the do loop
digitalWrite(forwards, HIGH);
 digitalWrite(backwards, HIGH);//Deactivate both relays to brake the motor
delay(2000);// wait 2
 digitalWrite(backwards, LOW);//Activate the relay to retract actuator, they must be different to move the motor
  delay(2000);// wait 2 seconds
@sterretje
Thank you!!! That was the problem My file name was 9 characters long.
