I need to make simple database on site with data stored on flash of ESP8266. I know that I need to use Fetch command but I am not sure how exactly should I implement it. Bellow you can find code that I have came up with using chat GPT and some inernet forums.
CSS one:
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include "webpageCode.h"
const int length = 15;
int index_user=0;
typedef struct {
String name;
String id;
} user;
user users[15]; // String array to hold user input
int userCount = 0; // Variable to keep track of the number of users
ESP8266WebServer server(80);
const int builtInLedPin = 2; // Assuming LED_BUILTIN is defined as 2, change if necessary
// Replace with your network credentials
const char* ssid = "GalaxyA526AF7";
const char* password = "12345678";
// Connect to Wi-Fi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi");
// Start the server
server.on("/", handleRoot);
server.begin();
Serial.println("HTTP server started");
// Set built-in LED pin as output
pinMode(builtInLedPin, OUTPUT);
// Initially turn off the built-in LED
switchOffBuiltInLed();
server.handleClient();
// Function to handle root URL
void handleRoot() {
if (server.arg("led") == "0") {
switchOnBuiltInLed();
} else if (server.arg("led") == "1") {
if (server.arg("user").length()>0) {
String temp = server.arg("user");
String temp2 = server.arg("id");
if(index_user<length){
users[index_user].name=temp;
users[index_user].id=temp2;
index_user+=1;
for( int i=0;i<index_user;i++){
Serial.print(users[i].name);
Serial.print(";");
Serial.print(users[i].id);
Serial.println("; ");
else{
Serial.println("Max users");
server.send(200, "text/html", webpageCode);
// Function to switch on the built-in LED
void switchOnBuiltInLed() {
digitalWrite(builtInLedPin, LOW); // Built-in LED is active low, so LOW turns it on
// Function to switch off the built-in LED
void switchOffBuiltInLed() {
digitalWrite(builtInLedPin, HIGH); // Built-in LED is active low, so HIGH turns it off
HTML one:
#ifndef WEBPAGE_CODE_H
#define WEBPAGE_CODE_H
const char webpageCode[] PROGMEM = R"=====(
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>ESP8266 Webpage (Diode controller and Userbase)</title>
<style>
body {
font-family: Arial, sans-serif;
background-color: #f0f0f0;
margin: 0;
padding: 0;
.container {
max-width: 600px;
margin: 20px auto;
padding: 20px;
background-color: #fff;
border-radius: 10px;
box-shadow: 0 0 10px rgba(0, 0, 0, 0.1);
h1 {
text-align: center;
margin-bottom: 20px;
.btn {
display: inline-block;
padding: 10px 20px;
margin: 0 10px 10px 0;
background-color: #4CAF50;
color: white;
text-decoration: none;
border: none;
border-radius: 5px;
cursor: pointer;
.btn:last-child {
margin-right: 0;
.user-table {
width: 100%;
border-collapse: collapse;
.user-table th, .user-table td {
border: 1px solid #ddd;
padding: 8px;
text-align: left;
.input-field {
width: calc(100% - 20px);
padding: 10px;
border-radius: 5px;
border: 1px solid #ccc;
margin-bottom: 10px;
.add-user-btn {
padding: 10px;
color: white;
border: none;
border-radius: 5px;
cursor: pointer;
</style>
</head>
<body>
<div class="container">
<h1>ESP8266 Webpage (Diode controller and Userbase)</h1>
<div>
<a href="?led=0" class="btn">Turn LED ON</a>
<a href="?led=1" class="btn">Turn LED OFF</a>
</div>
<!-- User Table -->
<table class="user-table">
<thead>
<tr>
<th>User ID</th>
<th>Username</th>
</tr>
</thead>
<tbody>
<!-- User data will be dynamically populated here -->
</tbody>
</table>
<!-- Add User Form -->
<input type="text" class="input-field" placeholder="Enter Username" id="usernameInput">
<button class="add-user-btn" onclick="addUser()">Add User</button>
</div>
<script>
// Function to add user to the table
function addUser() {
let username = document.getElementById('usernameInput').value;
if (username.trim() !== '') {
let tbody = document.querySelector('.user-table tbody');
let newRow = document.createElement('tr');
let userID=generateUserID();
newRow.innerHTML = '<td>' + userID + '</td><td>' + username + '</td>';
tbody.appendChild(newRow);
// Clear input field after adding user
document.getElementById('usernameInput').value = '';
fetch('/?user=' + username+'&id='+userID);
alert('Please enter a username.');
// Function to generate a random user ID
function generateUserID() {
return Math.random().toString(36).substr(2, 9);
</script>
</body>
</html>
#endif
