Dataflash not working
I'm bought a Dataflash 16Mb chip from sparkfun: DataFlash 16Mbit AT45DB161D - COM-00301 - SparkFun Electronics
And I'm trying without success to make something happen. Below is my bare bones code that attempts to write a byte to the buffer, and then read it back.
//DataFlash pins
byte MOSI = 11;
byte MISO = 12;
byte SCLK = 13;
byte CS = 8;
byte RESET = 9;
byte data;
  pinMode(MOSI, OUTPUT);
  pinMode(MISO, INPUT);
  pinMode(SCLK, OUTPUT);
  pinMode(CS, OUTPUT);
  pinMode(RESET, OUTPUT);
  digitalWrite(CS,HIGH);
  digitalWrite(RESET,HIGH);
  pinMode(5, OUTPUT);
  digitalWrite(5,HIGH);
  SPCR = B01010000;  // Set SPI config registry
  digitalWrite(CS,LOW);
  SPDR = B10000100;
  SPDR = B11111111;
  SPDR = B11111110;
  SPDR = B10100000;
  SPDR = B00111110;
  while(!(SPSR & (1 << SPIF)));
  SPDR = B11010100;
  SPDR = B11111111;
  SPDR = B11111110;
  SPDR = B10100000;
  SPDR = B11111111;
  //while(!(SPSR & (1 << SPIF)));
  digitalWrite(5,LOW);
  Serial.print(SPSR,DEC);
It gets stuck in the second while loop if I uncomment it. I copied that while loop form the playground: http://www.arduino.cc/en/Tutorial/SPIEEPROM but I'm not sure what exactly its doing. Supposedly SPIF, is a bit in SPSR, the status registry, however I don't understand why its being shifted, why it is its own variable, and why it shits the 1 7 bits, when a flag should only be 0 or 1. Anyway, I get 0 when I read it back, not what it should be..
