As a project from school i need to do the following:
I have to read the signal on a RS232 cable, and then i should be able to log all that data. It has to be a small setup, as it will be used in a tractor. this data comes from a weighing cell and there is enough time between different weighing moments. If possible, the datalogger should be easy to implement in excel.
How should i do this the best and are there some programming files available for this kind of problem, as i am a novice in programming.
You'll need to use a MAX232 chip to convert the RS232 levels to TTL levels for the Arduino to read.
You'll need to know (more than a little) about the format of the data coming from the device.
Getting EXCEL to run on the Arduino is going to be quite a challenge. Good luck.
Then why are you doing this project? It is NOT a beginner project. Oh, wait, I remember:
What is the field of study?
I read about the MAX232 chip. What i meant with 'easy to implement' is that if the data gets logged on a sd card or something that i can place all the data from the sd card easily to a excel file.
TBH i have not even a clue what the data format looks like.. all i know is that is from a weigh cell in the tractor. maybe if i can identify the weigh cell i can get a clue of the data format.. (i'll check it now)
I am studying automatisation, but we didnt get any decent programming at school so..
i was thinking about a max232 convertor, then go the arduino and logg it with a datalogging shield. but i dont have a clue about programming it, or is there another way to do this? i cant use a pc in the tractor, so has to be a small setup
