Hello There,
My project is to build a arduino nano based data logger with :
- arduino nano
- SPI sd card module
- I2C bme280 module
- little I2C oled screen module
For now i managed to get :
- DATA from BME280 on oled screen
- DATA from BME280 on the SD card file
but not both fuctions together due to the size apparently.
I have been struggeling for over 2 hours now, trying to reduce the size of my code.
You will see in the code I tried to comment out some of the strings i was creating.
I keep getting the same error message on IDE :
text section exceeds available space in boardSketch uses 31016 bytes (100%) of program storage space. Maximum is 30720 bytes.
Global variables use 1487 bytes (72%) of dynamic memory, leaving 561 bytes for local variables. Maximum is 2048 bytes.
Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
Error compiling for board Arduino Nano.
Any help will be very much appreciated!
thank you,
This is my code:
#include <BME280I2C.h>
#include <string.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
#include <SPI.h>
#include <SD.h>
int CS_PIN = 7;
Adafruit_SSD1306 display(OLED_RESET);
float sea_press = 101325;
BME280I2C bme; // Default : forced mode, standby time = 1000 ms
Serial.println("STARTED");
Wire.begin();
///////////////OLED DISPLAY INITIALISATION
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
Serial.println("welcome");
display.clearDisplay();
display.setTextSize(1.4);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.println("welcome");
display.display();
///////////////////BME280 initialisation
while(!Serial) {}
while(!bme.begin())
Serial.println("Could not find BME280 sensor!");
// bme.chipID(); // Deprecated. See chipModel().
switch(bme.chipModel())
case BME280::ChipModel_BME280:
Serial.println("Found BME280 sensor! Success.");
case BME280::ChipModel_BMP280:
Serial.println("Found BMP280 sensor! No Humidity available.");
default:
Serial.println("Found UNKNOWN sensor! Error!");
//////////////////////SD CARD init
Serial.print("Initializing SD card...");
pinMode(CS_PIN, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(CS_PIN)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
//mesure des valeurs et calcul alt
float temp(NAN), hum(NAN), pres(NAN);
int timer = millis()/1000;
bme.read(pres, temp, hum);
float alt = ((pow((sea_press / pres), 1/5.257) - 1.0) * (temp + 273.15)) / 0.0065;
float preshPa = pres/100;
//conversion en caracteres affichables
char temp_buff[5];
char hum_buff[5];
char pres_buff[5];
char alt_buff[5];
//char temp_disp_buff[20] = "Temp degC:";
//char hum_disp_buff[17] = "HR:";
//char pres_disp_buff[20] = "pressure hPa:";
//char alt_disp_buff[20] = "altitude m:";
// appending temp/hum to buffers
dtostrf(temp,4,1,temp_buff);
//strcat(temp_disp_buff,temp_buff);
dtostrf(hum,2,0,hum_buff);
//strcat(hum_disp_buff,hum_buff);
dtostrf(preshPa,6,2,pres_buff);
//strcat(pres_disp_buff,pres_buff);
dtostrf(alt,4,0,alt_buff);
//strcat(alt_disp_buff,alt_buff);
// routine for displaying text for temp/hum readout
display.println(temp_buff);
display.println(hum_buff);
display.println(pres_buff);
display.println(alt_buff);
display.display();
delay(2000);
//writing on the SD card
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println("time");
dataFile.println(timer);
dataFile.println("temp");
dataFile.println(temp);
dataFile.println("HR");
dataFile.println(hum);
dataFile.println("pres");
dataFile.println(pres);
dataFile.println("alt");
dataFile.println(alt);
dataFile.close();
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
