datalogger for counter sensor with RTC HELP!
//Program by Jeremy Blum
//www.jeremyblum.com
//SD Card Demonstration
//Some code from public domain work by Tom Igoe
//Assisted by Inigo D. Villanueva III
//Edited by Ignacio D. Villanueva III
//For thesis purpose entitled "
//Thesis members: James Santiago. Belen Cruz. Franzes Francisco, Kaye Agut
#include <SD.h>         //SD Card Library
//SPI SD Card Pins
  //MOSI = Pin 11
  //MISO = Pin 12
  //SCLK = PIN 13
  int CS_pin = 10;
  int pow_pin = 8;
// this constant won't change:
const int  buttonPinA = 2;    // the pin that the pushbutton is attached to
const int  buttonPinB = 5;
// Variables will change:
int buttonBeeCounterA = 0;   // counter for the number of button presses
int beeCounterA = 0;         // current state of the button
int lastBeeCounterA = 0;     // previous state of the button
int buttonBeeCounterB = 0;   // counter for the number of button presses
int beeCounterB = 0;         // current state of the button
int lastBeeCounterB = 0;     // previous state of the button
long lastEvent= 0; // The last time a bee has entered the feeding station
long interval= 300; // The debounce time
  Serial.println("Initializing Card");
  //CS Pin is an output
  pinMode(CS_pin, OUTPUT);
  //SD Card will Draw Power from Pin 8, so set it high
  pinMode(pow_pin, OUTPUT);
  digitalWrite(pow_pin, HIGH);
  //Initialize Card
  if (!SD.begin(CS_pin))
      Serial.println("Card Failure");
      return;
  Serial.println("Card Ready");
  // initialize the button pin as a input:
  pinMode(buttonPinA, INPUT);
  pinMode(buttonPinB, INPUT);
  // initialize serial communication:
  // read the pushbutton input pin:
  beeCounterA = digitalRead(buttonPinA);
  // compare the buttonState to its previous state
  if (beeCounterA != lastBeeCounterA)
    // if the state has changed, increment the counter
    if (beeCounterA == HIGH && millis() - lastEvent > interval)// Ignore this reading if it is too close to the last one
	lastEvent= millis(); // a bee can be recorded)
      // if the current state is HIGH then the button
      // wend from off to on:
      buttonBeeCounterA++;
      Serial.println("Bees are being detected entering Feeding Station A");
      Serial.print("number of bees that entered Feeding Station A:  ");
      Serial.println(buttonBeeCounterA);
    lastBeeCounterA= beeCounterA;
     beeCounterB = digitalRead(buttonPinB);
     if (beeCounterB != lastBeeCounterB)
    if (beeCounterB == HIGH && millis() - lastEvent > interval)// Ignore this reading if it is too close to the last one
      buttonBeeCounterB++;
      Serial.println("Bees are being detected entering Feeding Station B");
      Serial.print("number of bees that entered Feeding Station B:  ");
      Serial.println(buttonBeeCounterB);
      lastBeeCounterB= beeCounterB;
  //Write Log File Header
  File logFile = SD.open("DATALOG.csv", FILE_WRITE);
  if (logFile)
    logFile.print(buttonBeeCounterA);
    logFile.print(",");
    logFile.println(buttonBeeCounterB);
    Serial.print(buttonBeeCounterA);
    Serial.print(",");
    logFile.print("LogFile cannot be opened");
i wonder why there is no data being stored in my SD card, i have deleted the string and state it this way.. :cold_sweat: :cold_sweat: :cold_sweat: :cold_sweat:
