Datalogger temperature humidity whit display
Hi.
I’m trying to make a datalogger with a temperature and humidity sensor, an oled display and an sd card reader
I have a DHT22 sensor
a 0.96 "oled display (I2C)
Sd card reader (ICSP)
everything works well
but it does not work all at once.
I cant read sensor ant write in sd , and i cant read and show on screen.
but I can not do it all together.
this code readsensor and write in sd card
// Este lee el sensor y guarda los datos en la tarjeta sd
#include <SPI.h>
#include <SD.h>
//librerias del sensor
#include <DHT.h>
#include <DHT_U.h>
#include <Wire.h>
// librerias display
#include <Adafruit_SSD1306.h>
#include <splash.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <gfxfont.h>
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
// defines display
#define SCREEN_WIDTH 128 // OLED display ancho, en pixels
#define SCREEN_HEIGHT 64 // OLED display altura
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
//Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
File dataFile;
//File dataFile;
const int DHTPin = 12;     // pin digital del sensor
DHT dht(DHTPin, DHTTYPE);
  Serial.println("DHTxx test!");
  if (!SD.begin(4)) {
    Serial.println("Falta tarjeta");
    // don't do anything more:
    while (1);
  Serial.println("Iniciado correctamente.");
  dht.begin();
  // Pausa entre lecturas
  delay(2000);
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  if (isnan(h) || isnan(t)) {
    Serial.println("Error leyendo el sensor!");
    return;
  delay(200); // Pause for 2 seconds
  // Comienza guardar datos en sd
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // abre el archivo y guarda datos
  if (dataFile) {
    dataFile.print("Temp = ");
    dataFile.print(t);
    dataFile.print(" - Humed = ");
    dataFile.print(h);
    dataFile.println();
    dataFile.close();
    // print to the serial port too:
    Serial.print("Temp : ");
    Serial.print(t);
    Serial.print(" Humed : ");
    Serial.print(h);
  // mensaje de error si no se puede abrir el archivo
  else {
    Serial.println("error abriendo datalog.txt");
This one reads the sensor and shows the data on the screen
// Esta version muestra temperatura y humedad
// En el display y en monitor serie
#include <SD.h> //Libreria del lector de tarjeta
File logFile;
#include <SPI.h> //Libreria para bus SPI
#include "DHT.h" //libreria sensor temp/Humedad DHT
#include <DHT_U.h>
#include <Adafruit_GFX.h> //librerias display
#include <splash.h>
#include <Wire.h>
const int DHTPin = 13;     // pin digital del sensor
//RTC_DS3231 rtc;
  delay(2000);
  dht.begin();
  Serial.print("Iniciando SD ...");
  if (!SD.begin(4)) {
    Serial.println("No se pudo inicializar");
    return;
  Serial.println("inicializacion exitosa");
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
    Serial.println(F("SSD1306 allocation failed"));
    for (;;); // Don't proceed, loop forever
  display.display();
  delay(2000); // pausa
  // limpiamos el buffer
  display.clearDisplay();
  display.setTextSize(2);             // tama�o fuente
  display.setTextColor(WHITE);        // color
  display.setCursor(0, 4);            // Start at top-left corner
  display.println(F("Termometro V1"));
  display.display();
  delay(2000); // Pause for 2 seconds
  // pausa entre lecturas
  delay(2000);
  // Reading temperature or humidity takes about 250 milliseconds!
    Serial.println("No se puede leer el sensor!");
    return;
  Serial.print("Humedad: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperatura: ");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.println("");
  // muestra datos en pantalla
  display.display();
  display.setTextSize(2);             // tama�o del texto
  display.setCursor(0, 0);
  display.print("T: ");
  display.print(t);
  display.println();
  display.println();
  display.print("H: ");
  display.print(h);
  display.println();
  display.display();
  delay(200);
I tried other pins, in case there was some incompatibility, but the program stops when you try to open the file.
Food all by the USB of the arduino plate.
Can it be a feeding problem?
What do I do wrong?
pin_y_pon:
I don't think you tried hard enough. You have sensor on pin 12 which is MISO, and conflicts with SD
It's an Arduino Leonardo. Miso is in the ISCP connector.
Also, try it with 13, with 5, 9 ..
Aha! My apologies, I didn't realise they are different. If there IS no pin conflict and since you appear to know how to make everything go individually, you may be short of power when attempting to use them together, i.e. feeding indeed - not enough milliWatts.
