I am exploring options to add cellular to my project.
Here is my set up:
Remote sensor sending pulse counts via RF every 3 seconds to a Gateway. Gateway receives data from sensor and "prints" through Micro USB Serial to Yun "Host USB A". Python script logs pulse counts to sqlite database and adds timestamp. When I have an internet connection (wifi or ethernet) I have a python script that batch uploads data each night to a MySql database on a web server.
The request:
I need to add cellular to one location. The easiest would be to spend over $200, plus data plan, and buy an ethernet cellular modem.
Any solution must work around the Node/Gateway setup described above and the data rate of every three seconds. "Streaming" or sudo streaming is acceptable, batch uploading is acceptable. Timestamping is critical and must occur on the Yun. The sensor and gateway do not have RTC's to add an accurate timestamp. I have constant power 5V at 1.5A max, but can add battery to act as capacitor to cellular spikes if needed.
Anyone have any other suggestions for pushing the data to a web server?
