I'm Quite new to programming the ESP8266 with Arduino, I'm at the stage of cutting and pasting code from various sources to create what I need and learning along the way.
Hardware: ESP8266 board, 2.8" TFT Screen and a DS18B Temp Sensor
I've put together a datalogging sketch to log data to the screen over the past 48 hours as well as sending to a MQTT server for more long term storage.
HOWEVER
I have the updating of the data points drawn on the screen (and hence logging rate) via a time delay. I'm finding that under testing with a fast update / delay of 10,000 ms (10seconds) actually translates to more like 11 seconds between updates.
So I'm assuming something else in the code is skewing what I want to be the update / logging rate, and hence using a "delay" is not the best thing to use to set logging rate.
Any ideas on what would be a better way and (as I'm a beginner) how to implement it.
include <Wire.h>
#include <SPI.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <ESP8266WiFi.h>
#include <Ticker.h>
#include <AsyncMqttClient.h>
#include <PubSubClient.h>
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#include <Fonts/FreeSerif9pt7b.h>
#include <Fonts/FreeSans9pt7b.h>
#define TFT_DC D4
#define TFT_CS D8
#define WIFI_SSID
#define WIFI_PASSWORD "
#define MQTT_HOST IPAddress(192, 168, 1, 113)
#define MQTT_PORT 1883
#define MQTT_PUB_TEMP "esp/ds18b20/temperature"
const int oneWireBus = 5; //(GPIO5 - D1)
OneWire oneWire(oneWireBus);
DallasTemperature sensors(&oneWire);
float temp;
float xscale;
float del;
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
float humidity, temperature;
float min_temp = 100, max_temp = -100, min_humi = 100, max_humi = -100;
#define max_readings 290
#define del 10000 // measurement rate in ms 600000
float temp_readings[max_readings+1] = {0};
float humi_readings[max_readings+1] = {0};
int reading = 1;
#define temp_error_offset 1
#define humi_error_offset 1
#define autoscale_on true
#define autoscale_off false
#define barchart_on true
#define barchart_off false
void DrawGraph(int x_pos, int y_pos, int width, int height, int Y1Max, String title, float DataArray[max_readings], boolean auto_scale, boolean barchart_mode, int graph_colour) {
#define auto_scale_major_tick 5 // Sets the autoscale increment, so axis steps up in units of e.g. 5
#define yticks 15 // 5 y-axis division markers
int maxYscale = 0;
if (auto_scale) {
for (int i=1; i <= max_readings; i++ ) if (maxYscale <= DataArray[i]) maxYscale = DataArray[i];
maxYscale = ((maxYscale + auto_scale_major_tick + 2) / auto_scale_major_tick) * auto_scale_major_tick; // Auto scale the graph and round to the nearest value defined, default was Y1Max
if (maxYscale < Y1Max) Y1Max = maxYscale;
tft.drawRect(x_pos,y_pos,width+2,height+3,WHITE);
tft.setTextSize(2);
tft.setTextColor(graph_colour);
tft.setCursor(x_pos + (width - title.length()*12)/2,y_pos-20);
tft.print(title);
tft.setTextSize(1);
// Draw the data
int x1,y1,x2,y2;
for(int gx = 1; gx <= max_readings; gx++){
x1 = x_pos + gx * width/max_readings;
y1 = y_pos + height;
x2 = x_pos + gx * width/max_readings;
y2 = y_pos + height - constrain(DataArray[gx],0,Y1Max) * height / Y1Max + 1;
if (barchart_mode) {
tft.drawLine(x1,y1,x2,y2,graph_colour);
tft.drawPixel(x2,y2,graph_colour);
tft.drawPixel(x2,y2-1,graph_colour);
//Draw the Y-axis scale
for (int spacing = 0; spacing <= yticks; spacing++) {
#define number_of_dashes 40
for (int j=0; j < number_of_dashes; j++){ // Draw dashed graph grid lines
if (spacing < yticks) tft.drawFastHLine((x_pos+1+j*width/number_of_dashes),y_pos+(height*spacing/yticks),width/(2*number_of_dashes),WHITE);
tft.setFont();
tft.setTextSize(1);
tft.setTextColor(YELLOW);
tft.setCursor((x_pos-20),y_pos+height*spacing/yticks-4);
tft.print(Y1Max - Y1Max / yticks * spacing);
tft.setFont();
AsyncMqttClient mqttClient;
Ticker mqttReconnectTimer;
WiFiEventHandler wifiConnectHandler;
WiFiEventHandler wifiDisconnectHandler;
Ticker wifiReconnectTimer;
unsigned long previousMillis = 0;
const long interval = 10000;
void connectToWifi() {
Serial.println("Connecting to Wi-Fi...");
WiFi.begin(SSID,PASSWORD);
void onWifiConnect(const WiFiEventStationModeGotIP& event) {
Serial.println("C-Wi-Fi.");
tft.setTextColor(GREEN);
tft.setTextSize(1);
tft.setCursor(0,0);
// tft.print("WiFi");
connectToMqtt();
void onWifiDisconnect(const WiFiEventStationModeDisconnected& event) {
Serial.println("Disconnected from Wi-Fi.");
mqttReconnectTimer.detach();
wifiReconnectTimer.once(2, connectToWifi);
tft.setTextColor(RED);
tft.setTextSize(1);
tft.setCursor(0,0);
void connectToMqtt() {
Serial.println("CMQTT...");
mqttClient.connect();
tft.setTextColor(BLACK);
tft.setTextSize(1);
tft.setCursor(0,233);
tft.print("Re");
tft.setTextSize(1);
tft.print("Rem");
void onMqttConnect(bool sessionPresent) {
Serial.println("Connected to MQTT.");
Serial.print("Session present: ");
Serial.println(sessionPresent);
tft.setTextSize(1);
tft.print("Remote Database: Connecting.....");
tft.setTextSize(1);
tft.print("Remote Database: Conneted");
void onMqttDisconnect(AsyncMqttClientDisconnectReason reason) {
Serial.println("Disconnected from MQTT.");
tft.setTextSize(1);
tft.print("Rem.");
tft.setTextSize(1);
tft.print("Rem");
tft.setTextSize(1);
tft.print("Rem");
tft.setTextSize(1);
tft.setCursor(265,0);
tft.print("DB :OK");
tft.setTextSize(1);
tft.setCursor(270,0);
tft.print("DB:FAIL");
if (WiFi.isConnected()) {
mqttReconnectTimer.once(2, connectToMqtt);
void onMqttPublish(uint16_t packetId) {
Serial.print("Publish acknowledged.");
Serial.print(" packetId: ");
Serial.println(packetId);
tft.setTextSize(1);
//tft.print(packetId);
void setup(){
wifiConnectHandler = WiFi.onStationModeGotIP(onWifiConnect);
wifiDisconnectHandler = WiFi.onStationModeDisconnected(onWifiDisconnect);
mqttClient.onConnect(onMqttConnect);
mqttClient.onDisconnect(onMqttDisconnect);
mqttClient.onPublish(onMqttPublish);
mqttClient.setServer(MQTT_HOST, MQTT_PORT);
connectToWifi();
sensors.begin();
tft.begin();
tft.setRotation(3);
tft.setTextSize(2);
tft.setTextColor(WHITE);
tft.fillScreen(BLACK);
analogWriteFreq(500);
analogWrite(D0, 750);
for (int x = 0; x <= max_readings; x++){
temp_readings[x] = 0;
humi_readings[x] = 0;
void loop(){
sensors.requestTemperatures();
temp = sensors.getTempCByIndex(0);
float temperature = sensors.getTempCByIndex(0);
int temp=sensors.getTempCByIndex(0);
int unit=temp%10;
int tens=temp/10;
float rem=temperature-temp;
int temp1=rem*100;
int tens1=temp1/10;
int unit1=temp1%10;
tft.setFont(&FreeSans9pt7b);
DrawGraph(20,20,290,180,30,"",temp_readings, autoscale_off, barchart_off, RED); //YI_Max is the Y scale max figure.
tft.setFont();//reset font
reading = reading + 1;
if (reading > max_readings) {
reading = max_readings;
for (int i = 1; i < max_readings; i++) {
temp_readings[i] = temp_readings[i+1];
humi_readings[i] = humi_readings[i+1];
temp_readings[reading] = temperature;
delay(del); //Data logging rate???
if (currentMillis - previousMillis >= interval) {
uint16_t packetIdPub1 = mqttClient.publish(MQTT_PUB_TEMP, 1, true, String(temp).c_str());
Serial.printf("Publishing on topic %s at QoS 1, packetId: %i ", MQTT_PUB_TEMP, packetIdPub1);
Serial.printf("Message: %.2f \n", temp);
xscale = (290 * (((del / 1000))/60)/60)/2;
