Datalogging on SD problem
Hi everybody;
I didn’t know where to bring up my problem so i came here.
I am using this code to write the data i get from analog input on an SD card.
      file.open(file_name, ios::app | ios::out);
      if (!file.is_open())
        GLCD.CursorTo(0,3);
        GLCD.print("open error!!");
      file << _hour << ':' << _minute << ':' << _second;
      file << "     " << "sensor " << analog_counter << " : ";
      file << analog_input(analog_counter) << endl;
      if (file.bad())
        GLCD.CursorTo(0,4);
        GLCD.print("write error!!");
      file.close();
      file.clear();
as you may see file is an instance of ofstream and analog_input is the data which is read from analog pins. I have a DS1307 which gives me the real time and i get _hour and _minute and _second from that.
i use this code as a function and call it whenever i need it which is pretty much more than 50 times a second i think.
I don’t see why, but i keep receiving the error codes on my LCD.
file_name is the date like 20130716.txt.
I use this function to open the file and append to it. i have another function to make the file_name and make another file for me in case day or month or year have changed.
    _year=RTC.get(DS1307_YR,true);
    _month=RTC.get(DS1307_MTH,true);
    _day=RTC.get(DS1307_DATE,true);
      itoa(_year,name1,10);
      itoa(_month,name2,10);
      itoa(_day,name3,10);
      if (name2[1]=='\0')
        key=name2[0];
        name2[0]='0';
        name2[1]=key;
      if (name3[1]=='\0')
        key=name3[0];
        name3[0]='0';
        name3[1]=key;
      for (byte i=0;i<4;i++) file_name[i]=name1[i];
      file_name[4]=name2[0];
      file_name[5]=name2[1];
      file_name[6]=name3[0];
      file_name[7]=name3[1];
      file_name[8]='.';
      file_name[9]='t';
      file_name[10]='x';
      file_name[11]='t';
      if (sd.exists(file_name)) return;
      logfile.open(file_name, ios::app | ios::out);
        GLCD.CursorTo(0,1);
        GLCD.print("make error!!");
      logfile << "some text1" << endl;
      logfile << "some text2" << endl;
      logfile << "some text3" <<endl;
      if (!file)
        GLCD.CursorTo(0,2);
        GLCD.print("file error!!");
      file.close();
      file.clear();
      logfile.close();
i use this code to make another file. at first run this code works pretty fine and makes me a file. but when i change date and call this function i start getting the error codes i have defined on LCD and no file is made for me. when i reset the arduino it make me my new file because the date that i have changed stays in DS1307.
can anyone make any sense of this program and tell me what i have done wrong?
any help is greatly appreciated.
Thanks everyone who viewed this topic and everyone who had an answer for but didn’t get time to reply me.
I found mt own answer. the answer is the null character at the end of the file_name. That’s it. the dumbest thing that you may ever think of. and of course stuck me for a whole week to find the answer.
I hope you keep that in mind and don’t stuck like me.
