Date and time with ms precision
Hi all!
I am working on monitoring the electric conssumption of a machine. I do it with Circuit Setup SSP Energy Meter (which includes an ESP32 and an ATM90E32) sampling every 50ms. I am sending data via MQTT to a Raspberry Pi, and storing it for further analysis, for what I am using a Python script and SQLite.
Now I'm working with other (possibly faster) communication alternatives such as the Serial port, SPI or probably I2C.
My question is: Is there any way of sending data through (for example the Serial port which I think is the easiest to start with) in a format like this?:
day / month / year - / hour / minute / second / milisecond
I can do it in the Python script but I think it would be more accurate to keep the time of the measurement and not the time of data storage. The code fragment for the Serial port is this one:
#define ESP32
#include <ArduinoJson.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <PubSubClient.h>
#include <SPI.h>
#include <ATM90E32.h>
  Serial.println("Voltage 1: " + String(voltageA) + "V");
  Serial.println("Current 1: " + String(currentCT1) + "A");
  Serial.println("Current 2: " + String(currentCT2) + "A");
  Serial.println("Active Power: " + String(realPower) + "W");
  Serial.println("Power Factor: " + String(powerFactor));
  Serial.println("Harmonic Power: " + String(eic.GetTotalActiveHarPower()) + "W");
  Serial.println("Reactive Power: " + String(eic.GetTotalReactivePower()) + "var");
  Serial.println("Apparent Power: " + String(eic.GetTotalApparentPower()) + "VA");
  Serial.println("Phase Angle A: " + String(eic.GetPhaseA()));
  Serial.println("Chip Temp: " + String(temp) + "C");
  Serial.println("Frequency: " + String(freq) + "Hz");
I can provide the full code if needed, but I don't think it's necessary.
Thanks for your time and help.
do you have a way to sync your clock to the "real" ms?
If you have the data then why not
If you are using an ESP32 you can use Serial.prinft() to format the output string, lowercase s, not a String, uppercase S
