Hello,
I am wanting to assign the filename of my recording as the current date.
This is the current code I have got and get the error message:
no matching function for call to 'SdFile::open(File&, int)'
I am very new to coding with an Arduino and probably not understanding things very well.
// Include libraries
#include <SdFat.h>
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#include <DS3231.h>
// Init the DS3231 using the hardware interface
DS3231 rtc(SDA, SCL);
File filename;
// SD card objects
SdFat sd;
SdFile rec;
// Constants
const int chipSelect = 10;
unsigned long fileSize = 0L;
unsigned long waveChunk = 16;
unsigned int waveType = 1;
unsigned int numChannels = 1;
unsigned long sampleRate = 22050;
unsigned long bytesPerSec = 22050;
unsigned int blockAlign = 1;
unsigned int bitsPerSample = 8;
unsigned long dataSize = 0L;
unsigned long recByteCount = 0L;
unsigned long recByteSaved = 0L;
const int ledStart = 7;
int recPressed = 0;
int stopPressed = 0;
unsigned long oldTime = 0L;
unsigned long newTime = 0L;
// Buffers
byte buf00[512]; // buffer array 1
byte buf01[512]; // buffer array 2
byte byte1, byte2, byte3, byte4;
unsigned int bufByteCount;
byte bufWrite;
// Counter
byte recordingEnded = false;
unsigned int counter;
unsigned int initial_count;
unsigned int maxCount = 5 * 1000; // 5 Seconds
void setup() { // THIS RUNS ONCE
// Setup timer & ADC
Setup_timer2();
Setup_ADC();
// Set output pins
pinMode(10, OUTPUT);
pinMode(ledStart, OUTPUT);
// Initialize the rtc object
rtc.begin();
// Init SD card
if (sd.begin(chipSelect, SPI_FULL_SPEED)) {
for (int dloop = 0; dloop < 4; dloop++) {
digitalWrite(ledStart,!digitalRead(ledStart));
delay(100);
// If error
else {
while(1) {
// Start recording
StartRec();
// Init counter
initial_count = millis();
void loop() { // THIS RUNS LOTS!
String filename = rtc.getDateStr();
filename += ".wav";
// Update counter
counter = millis() - initial_count;
// Stop recording if counter reached
if (counter > maxCount && !recordingEnded) {
recordingEnded = true;
StopRec();
// Update recording
if (recByteCount % 1024 == 512 && recPressed == 1) { rec.write(buf00,512); recByteSaved+= 512; } // save buf01 to card
if (recByteCount % 1024 == 0 && recPressed == 1) { rec.write(buf01,512); recByteSaved+= 512; } // save buf02 to card
void StartRec() { // begin recording process
digitalWrite(ledStart,HIGH);
recByteCount = 0;
recByteSaved = 0;
recPressed = 1; // recording button has been pressed
stopPressed = 0;
writeWavHeader();
sbi (TIMSK2, OCIE2A); // enable timer interrupt, start grabbing audio
void StopRec() { // stop recording process, update WAV header, close file
cbi (TIMSK2, OCIE2A); // disable timer interrupt
writeOutHeader();
digitalWrite(ledStart,LOW); // turn off recording LED
recPressed = 0;
void writeOutHeader() { // update WAV header with final filesize/datasize
rec.seekSet(4);
byte1 = recByteSaved & 0xff;
byte2 = (recByteSaved >> 8) & 0xff;
byte3 = (recByteSaved >> 16) & 0xff;
byte4 = (recByteSaved >> 24) & 0xff;
rec.write(byte1); rec.write(byte2); rec.write(byte3); rec.write(byte4);
rec.seekSet(40);
rec.close();
void writeWavHeader() { // write out original WAV header to file
recByteSaved = 0;
rec.open(filename, O_CREAT | O_TRUNC | O_RDWR);
rec.write("RIFF");
byte1 = fileSize & 0xff;
byte2 = (fileSize >> 8) & 0xff;
byte3 = (fileSize >> 16) & 0xff;
byte4 = (fileSize >> 24) & 0xff;
rec.write("WAVE");
rec.write("fmt ");
byte1 = waveChunk & 0xff;
byte2 = (waveChunk >> 8) & 0xff;
byte3 = (waveChunk >> 16) & 0xff;
byte4 = (waveChunk >> 24) & 0xff;
byte1 = waveType & 0xff;
byte2 = (waveType >> 8) & 0xff;
byte1 = numChannels & 0xff;
byte2 = (numChannels >> 8) & 0xff;
byte1 = sampleRate & 0xff;
byte2 = (sampleRate >> 8) & 0xff;
byte3 = (sampleRate >> 16) & 0xff;
byte4 = (sampleRate >> 24) & 0xff;
byte1 = bytesPerSec & 0xff;
byte2 = (bytesPerSec >> 8) & 0xff;
byte3 = (bytesPerSec >> 16) & 0xff;
byte4 = (bytesPerSec >> 24) & 0xff;
byte1 = blockAlign & 0xff;
byte2 = (blockAlign >> 8) & 0xff;
byte1 = bitsPerSample & 0xff;
byte2 = (bitsPerSample >> 8) & 0xff;
rec.write("data");
byte1 = dataSize & 0xff;
byte2 = (dataSize >> 8) & 0xff;
byte3 = (dataSize >> 16) & 0xff;
byte4 = (dataSize >> 24) & 0xff;
void Setup_timer2() {
TCCR2B = _BV(CS21); // Timer2 Clock Prescaler to : 8
TCCR2A = _BV(WGM21); // Interupt frequency = 16MHz / (8 x 90 + 1) = 22191Hz
OCR2A = 90; // Compare Match register set to 90
void Setup_ADC() {
ADMUX = 0x40; // set ADC to read pin A5, ADLAR to 1 (left adjust)
cbi(ADCSRA,ADPS2); // set prescaler to 8 / ADC clock = 2MHz
sbi(ADCSRA,ADPS1);
sbi(ADCSRA,ADPS0);
ISR(TIMER2_COMPA_vect) {
sbi(ADCSRA, ADSC); // start ADC sample
while(bit_is_set(ADCSRA, ADSC)); // wait until ADSC bit goes low = new sample ready
recByteCount++; // increment sample counter
bufByteCount++;
if (bufByteCount == 512 && bufWrite == 0) {
bufByteCount = 0;
bufWrite = 1;
} else if (bufByteCount == 512 & bufWrite == 1) {
bufByteCount = 0;
bufWrite = 0;
if (bufWrite == 0) { buf00[bufByteCount] = ADCH; }
if (bufWrite == 1) { buf01[bufByteCount] = ADCH; }
// if (recByteCount % 1024 < 512) { // determine which buffer to store sample into
// buf01[recByteCount % 512] = ADCH;
// } else {
// buf02[recByteCount % 512] = ADCH;
