Datos bluethoot 1 vez por segundo
Hola compañeros.
Tengo un dispositivo que envía 1 vez por segundo datos a mi modulo HC-05 y Arduino los recibe correctamente. Me gustaría forzar en arduino más lecturas por segundo, aunque se repitan. ¿Podéis ayudarme por favor? Gracias. Adjunto el código:
// Arduino Bluetooth Interface with Mindwave
// This is example code provided by NeuroSky, Inc. and is provided
// license free.
#define LED 13
#define BAUDRATE 57600
#define DEBUGOUTPUT 0
#define powercontrol 10
// checksum variables
byte generatedChecksum = 0;
byte checksum = 0;
int payloadLength = 0;
byte payloadData[64] = {
 0};
byte poorQuality = 0;
byte attention = 0;
byte meditation = 0;
// system variables
long lastReceivedPacket = 0;
boolean bigPacket = false;
// Microprocessor Setup //
 pinMode(LED, OUTPUT);
 Serial.begin(BAUDRATE);           // USB
// Read data from Serial UART //
byte ReadOneByte() {
 int ByteRead;
 while(!Serial.available());
 ByteRead = Serial.read();
#if DEBUGOUTPUT
 Serial.print((char)ByteRead);   // echo the same byte out the USB serial (for debug purposes)
#endif
 return ByteRead;
//MAIN LOOP//
 // Look for sync bytes
 if(ReadOneByte() == 170) {
     payloadLength = ReadOneByte();
     if(payloadLength > 169)                      //Payload length can not be greater than 169
         return;
     for(int i = 0; i < payloadLength; i++) {
       payloadData[i] = ReadOneByte();            //Read payload into memory
       generatedChecksum += payloadData[i];
     checksum = ReadOneByte();                      //Read checksum byte from stream
     generatedChecksum = 255 - generatedChecksum;   //Take one's compliment of generated checksum
       if(checksum == generatedChecksum) {
       poorQuality = 200;
       attention = 0;
       meditation = 0;
       for(int i = 0; i < payloadLength; i++) {    // Parse the payload
         switch (payloadData[i]) {
         case 2:
           i++;
           poorQuality = payloadData[i];
           bigPacket = true;
         case 4:
           i++;
           attention = payloadData[i];
         case 5:
           i++;
           meditation = payloadData[i];
         case 0x80:
           i = i + 3;
         case 0x83:
           i = i + 25;
         default:
         } // switch
       } // for loop
#if !DEBUGOUTPUT
       // *** Add your code here ***
       if(bigPacket) {
         if(poorQuality == 0)
           digitalWrite(LED, HIGH);
           digitalWrite(LED, LOW);
         Serial.print("PoorQuality: ");
         Serial.print(poorQuality, DEC);
         Serial.print(" Attention: ");
         Serial.print(attention, DEC);
         Serial.print(" Time since last packet: ");
         Serial.print(millis() - lastReceivedPacket, DEC);
         lastReceivedPacket = millis();
         Serial.print("\n");
#endif
       bigPacket = false;
     else {
       // Checksum Error
     }  // end if else for checksum
   } // end if read 0xAA byte
