Hi guys
I´ve build a midi to trigger module.
It converts each "note on" into a trigger , starting from C1.
It works great if I receive notes with intervals , with little delay between them.
Like the following picture.
But , if I receive all notes together, like a chord (C1+D1+E1) , the "HandleNoteOn" consider only one "note on" ( I cant remember each one now).
How to pool all "note on" and fire all "chord" triggers?
Trigger *triggers[MAXTRIGGERS] = {&t8, &t9, &t10, &t11, &t12, &t13, &t2, &t3, &t4, &t5, &t6, &t7};
// Serial.begin(9600);
MIDI.begin(MIDI_CHANNEL_OMNI);
MIDI.setHandleNoteOn(HandleNoteOn);
for (int i = 0; i < MAXTRIGGERS; i++)
triggers[i]->setLenght(20);
//trigger check
triggers[i]->start();
delay(TESTDELAY);
triggers[i]->end();
MIDI.read();
triggers[i]->compute();
void HandleNoteOn(byte channel, byte pitch, byte velocity)
if ((pitch >= PITCHSTART) && (pitch < (PITCHSTART + MAXTRIGGERS)))
if (velocity > 0)
triggers[pitch - PITCHSTART]->start(ELECTROMECANICALTRIGGERLENGHT);
// else
// triggers[pitch - PITCHSTART]->end();
TIA
Gibran
Your code looks very odd, have you posted all of it? In particular I can’t see where the midi comes in and how you remove the trigger from stuff. If you are using delay then that will screw you up.
I did a similar project years ago, you can see it here.
http://www.thebox.myzen.co.uk/Hardware/Glockenspiel.html
Hi Grumpy
I already did some code cleaning and reached the following version.
But I think that my USB/MIDI interface have something to do with the problem.
No matter how many notes I send together on a chord from Ableton , I receive only one package on arduino , only the first note.
I installed a MIDI monitor and it receives all notes from Ableton.
I´ll take a look on your code today !
Thank you !
byte _incomingByte;
byte _pitch;
byte _velocity;
while (Serial.available() > 2)
_incomingByte = Serial.read();
_pitch = (int)Serial.read();
_velocity = (int)Serial.read();
if ((_incomingByte == 0x90) &&
(((_pitch >= PITCHSTART) && (_pitch < (PITCHSTART + MAXTRIGGERS)) && (_velocity > 0))))
triggers[_pitch - PITCHSTART]->start(ELECTROMECANICALTRIGGERLENGHT);
Hi Grumpy
I merged your code with mine and again , chords reaches arduino like like one first note.
Maybe its time to test another USB interface.
Many thanks
Again you are not posting all the code. In that project I linked to the time the trigger lasts is controlled by a monostable, a hardware chip.
How are you controlling the time the trigger signal lasts for? I suspect it is this bit of the code that is blocking reception of the other MIDI messages.
I did do another project like this in my book, Arduino Music and Audio Projects | SpringerLink you can download the software from that page.
That uses all software to determine how long a note lasts by timing the arrival of the note and using a state machine like the blink without delay example, so that it is none blocking.
This video MIDI Beater - YouTube doesn’t show more than one thing being hit at the same time but it will do that.
