I am completely new to Arduino and I'm extremely interested in a project that turns on smart plugs when the Arduino detects a certain event. The simplest thing I can think of is a daylight sensor that will turn on a smart light when it gets dark. I've seen the tutorial that uses Alexa to turn on an LED on the Arduino, but I need to do something the other way. (Arduino turn on something connected to Alexa) Is this possible?
Can it be done? Yes, I don't see why not. You may want to start by giving this a read.
You can just program Alexa to for example turn something On/Off at sunset. Anyway the link should give you an idea of what's involved using Arduino.
Ron
You don't normally need to go through Alexa or the Internet...
You need to know what protocol your smart plugs use. I think the "big companies" are trying to standardize on Zigbee but Alexia should work with any of them . Do you have a home automation hub? If you don't have a hub they are Wi-Fi and you'll need to connect your Arduino to Wi-Fi.
Direct Wi-Fi isn't that popular for home automation. There are a few competing standards and no clear winner yet.
Wi-Fi should also be an option with one of the home automations protocols and a hub. These things are usually accessed through a browser or an app so it may not be "easy" to control them with an Arduino.
I have a Z-Wave system and a programmable "smart hub". Mostly the hub runs stand-alone with some lights programmed for sunrise/sunset (1) and other times. Or I can access the hub with my laptop (Wi-Fi) to "manually" control things.
My home automation isn't set-up for Alexis or access over the Internet or the cell phone network... I don't need that. And everything is off-the-shelf. I didn't build any of it myself.
You can get various sensors for the various protocols. The sensor communicates with the hub, and the hub is programmed to "do something". There are a couple of 6-way sensors that can measure light, temperature, motion, and I can't remember what else. And you can usually find a "universal" transmitter that you can trigger with a relay, or an alarm system, or an Arduino, etc.
(1) You program-in your location and the firmware knows the sunrise/sunset times throughout the year. (I don't have a light sensor). The time-of-day timers automatically adjust for daylight savings time.
Now looking at sonoff in DIY mode. Just send api json using arduinojson library. Something to have a play with. Ill update later and no need for cloud.
I used some code ( few yrs ago now ) that mimicked a commercial device that already has a skill .
Sorry can’t recall where from , but on an 8266 it worked fine
