dayShortStr() French
I try to find a way to use the timelib function dayShortStr() to give days in French (Lundi, Mardi, etc…)
Is there a way to do it?
Thanks in advance.
Patrice
Go to the folder where the library is installed and change the values in DateStrings.cpp :slight_smile:
EDIT: Make sure that the “dt_MAX_STRING_LEN” define in “TimeLib.h” is set to a value long enough to hold the longest value you specify.
Perfect. Thanks a lot.
