DC Amplifier Boards
I was wondering if anybody was aware of a source of DIN carrier mounted, 5(or 3.3)V trigger/12(or 12 to higher)V output, N-channel acting PCB modules, with paired side-by-side (aka 1+, 1-, 2+, 2-, etc.) outputs, preferably with high-quality, rising-cage-style (usually light-green) 5.10mm pitch screw terminals and preferably common-ground (only one input ground per board, not input 1+, input 1 gnd, input 2+, input 2 gnd, etc.) inputs, either screw or 2.54mm pitch male input terminals (or both). I haven't been able to seem to find anything in this form factor in mosfet amplifiers, only slow traditional relays.
You could always design your own board as you know exactly what you want.
Nice to know what inputs you need. But what does it do with them?
I think he simply wants some DIN mounted ‘open drain’ N-FET output drivers.
In that he’ll also need to specify the ratings needed.
There's this but it's only 1A per output (probably conservatively rated).
I suspect that for something like this you'll need to DIY.
